Cold Belt Noise
When you start a car and their is a squeek noise, if you spray the belt with a water bottle and the noise goes away its the belt. If its a constant noise or metalic sound its bearing. I still never would put anything on a belt. A belt thats to tight or to lose will cause a noise also.
As far as the tuner, it's Dyno Tuned Performance. They are now Hemi-guys, but after talking to Brent, I feel comfortable with him. Also, I told him I like the tranny as it is so it wouldn't be messed with.
I don't have a lot of options at this point and they do have a good reputation. They just tuned a 2010 or 11 F-150 w/Pro-Charger that made 500 rwhp, along with another 150, so mine won't be the first truck they have seen.
It could be too tight I guess.
I've had tuners with VERY good reputation tune my truck and although they can get the big numbers, drive-ability and gas mileage severely suffer. Ultimately letting JDM tune my tuck resulted in the best numbers all around.
JDM did A LOT of tuning on your transmission, although you might think it feels stock. That's the beauty of the JDM/Troyer tune that unless the tuners are very familiar with the 04+ trucks they will never get right.
Well good luck...
JDM did A LOT of tuning on your transmission, although you might think it feels stock. That's the beauty of the JDM/Troyer tune that unless the tuners are very familiar with the 04 trucks they will never get right.
He wasn't supposed to touch the tranny tune, so all I can do is assume he didn't. He said he added a couple degrees of timing and some fuel at the top end.
I posted the sheets on the sticky and will post them in the "I pulled the trigger" thread.
Im using my VMP tune right now as I've been on troyers for a few months. I can vouch for either I really like the part throttle of VMP as the Troyer is very touchy and doesnt seem to downshift when I want it to. I need to get my truck on a dyno again and run both tunes to see who makes more power.
Like I said, I will get up to JDM "one day". I'll be in Yuma on Sunday and be there through June. It's not too far away, maybe I'll come up one Sat.
Yuma huh? I was there a couple times myself for WTIs at the Marine base, was way too hot for me.
Both were mail order tunes, I data logged on the free way for Justin @ VMP and went to a dyno and data logged for Troyer. They both sent me a tune with about 10-20% more fuel. Justins 2nd tune is now dead on with my wideband and troyers was dead on with my wideband from the start. The dynos wideband said I was lean so troyer corrected for it, however my truck is way overly rich now and throws rich codes. I waited forever for my troyer tune and actually contacted Justin while waiting for my troyer tune and got it long before the troyer tune. WOT feels good on both and like I said the Troyer tune is really odd at part throttle but its how he sets up the throttle body. Justins tune doesnt have that "free" feeling with the gas pedal that the troyer tune does but it has perfect driveability.
Hmm, I just drove the truck and took notes of where and when it upshifted and downshifted as well as throttle position and then noted what I wanted it to do. Emailed it to Mike and he made the changes. Even then when I realized some of the things I wanted it to do were not as good an idea as I thought he made more changes. He has always told me "do not settle, you should never feel you have to accept or live with anything, just let me know what you want and I'll make the changes". Thus far he has done so and the truck does exactly what I want. With the last changes he threw in something extra and blew me away. Regardless of vehicle speed anything past 80% throttle in first lights up the rear tires and burns them up into second. I love it. Anything more than 33-35% throttle from a stand still lights em up. Mike has been great to deal with and worked with me through the throttle sensitivity as well. But it's like he told me not everyone wants a hot throttle so he doesn't start them out that way. I told him I wanted the throttle as hot as possible and he made it happen.
On another note I wouldn't waste anytime comparing tunes on a dyno. Dyno #'s are useless and good for one thing and thats talk. The strip is where these battles should be fought imo.
I realize dyno and quartermile isnt really the best way to judge a tune as they are both doing different things and there are way to many variables. However if were to run both on a dyno and they made the same power, and then run them both at the track and run the same numbers I would run VMP over troyer just for the fact that it shifts when I want and I wouldnt have people who drive my truck ask me why it power surges or falls on its face at a random RPM with random Pedal postion
Mike is actually 5hrs from me. I've only been there once and that was last summer to get a fuel system and tune. Since then we have played with the tunes via email based on my demands. Not sure about the surges you are feeling. Mine pulls like a bitch and its constant. I especially love mid throttle when she's only making about 3-5psi. With that and the torque multiplication of this circle d converter she keeps me against the seat. One thing I have learned is that no tune is so perfect you just drive away from the dyno and are 100% happy the first time. If so then your not very in touch with vehicle. It takes the engineer's for car companies months to get the tunes dialed in. It's no different here. Personally I love the quest for perfection and the trial and error. I eat and breath this stuff. And then just when you get it right you add more power or different parts and the fun begins again
The surges are a BIG complaint about Troyers tune on the Saleen forum. Troyer claims it's normal and nothing can be done about it. The Saleen guys got fed up and said forget it. Went to other tuners(mainly JDM) and the problem went away. If troyer told me that is "normal" I would have told him to get bent...
Twin, how you describe your truck runs is how mine is. Part/half throttle running about 5psi the damn truck will still plant you in your seat. It's just plain absolute blast to drive. I wish my stall was bigger like yours(mine is around 3000), but I'm waiting for my new engine build before I re-stall.
I love that feeling of raw power. It's like driving a viper verses a vette. Vipers way more fun cause there's no onboard computer crap keeping the car under control. At least that's the way it was till recently. Now the government has ruined that for the viper crowd.
Hell we raised hell when they added GPS and cup holders to a viper, lmao.
