F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
Old 11-03-2009, 12:26 AM
2000 F250 5.4 supercharger???
I have a 2000 F250 4x4, automatic, with a 5.4 and i am completly disgusted with the amount of pulling power or lack there of! However the truck is paid for and i am not going to jump back into payments as tempting as that sounds. The truck has 100,000 miles and i keep up with the maintenance very well, the truck has absoulutely no problems. So my question is what will give me the most bang for the buck as far as overall power for towing. I use the truck as my daily driver and use it to pull our 23' fifth wheel (very light) camper. Could i use a stock charger off of a lightning? would it bolt right up if so how hard would this be and what all would i need? any advice would be greatly appreciated!!!
Old 11-03-2009, 09:38 AM
Vehicle: 2003 Ford F150
Don't know why you couldn't go with L swap. Obviously IC heat exchanger brackets, fan shroud and IC coolant tank might be mounted different, but I do not see that it would be that hard. If you shop around you can pick up L parts. The positive displacement blower is the way to go for towing. With a 5000lb pull on hiily roads I can set the cruise at 75 in overdrive and never think about it. I'm only running 3.73 gears with 32in tires so at 75 I'm pulling about 2200rpm. The positive displacement blower adds a lot of low end torque and this is what these truck are lacking. The other day I was puling my car trailer with 6000lbs of Wood Pellets (>8000lbs total weight) and I just started to have to use the gas pedal. And yes that exceed's the towing capacity of my F150, but I was keep it below 75 and I only went 5 miles. If you need more info PM you email,
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
Old 11-03-2009, 01:42 PM
Vehicle: 2000 Ford F-150
Can I do the same thing on my 00' F150? Just use a lightning blower and injectors etc.? I could then have it tuned right? Or could I send in the specifics to Bill at PHP and have him do it all with a custom tune for my Gryphon??
2000 F-150 Lariat 5.4L, Gryphon Tuned by PHP, S&B CAI, Magnaflow Magnapack, DynaPro M/T's, RCD 5" Lift & 2" ProComp AAL
Old 11-03-2009, 01:55 PM
Quote:
Yes just read any of the posts within this section of the forum. Any talk of an Lightning blower swap is tied to the 98-2003 F150's (plus 2004 Lariats) and Expediations (some maybe all 2004's) which are 2 valve 5.4 motors.
Old 11-03-2009, 08:36 PM
Quote:
my email is whitenova69@hotmail.com thanks for the response and any advice or help you can offer will be greatly appreciated
Old 11-04-2009, 03:45 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
use the search feature and read the many swap threads...
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 11-05-2009, 12:11 AM
Vehicle: 1998 Ford F150
There are tons of threads about this swap... I did it to mine
Old 11-05-2009, 08:04 AM
emailed info!!!
Old 11-05-2009, 10:18 PM
emailed info!!!
i got it! thanks for all your help. now the search begins for parts. wish i could find someone parting out a lightning so i could get everything including the computer. any ideas?
Old 11-06-2009, 03:04 AM
Vehicle: 200? FORD
classifieds...
Old 11-06-2009, 03:13 AM
Vehicle: 200? FORD
I also know a couple people who have complete setups they'd be willing to part with...
Old 11-06-2009, 03:36 PM
Vehicle: 2003 Ford F-150
burkleo24 just making sure since i didn't see it mentioned, but you don't need the whole motor just everything above the heads, i think ford will sell the Harley take-off as a replacement part(don't know the guys at my parts counter told me they can get anything). but also getting a computer would make it easier for you but the person doing the tuning can make it work either way.
Factory Tech Separator Plate-http://www.youtube.com/watch?v=im7n-pXeE4k
Old 11-06-2009, 04:25 PM
Vehicle: 200? FORD
Jimmy, he won't need an ECU
Old 11-06-2009, 04:31 PM
Yeah, don't go with Lightning ECM. If you did you would have to get an L frame harness and other stuff as well. A good tuner can make the NA ECM work just fine. The first tune I received was via email and the truck started up the first time, idled fine and ran good. Then I found out it was closed loop and I made a change.
Old 11-08-2009, 11:47 AM
Quote:
could you point me in their direction i am ready to find everything and get started. asap
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
