Quote:
Originally Posted by nonwoven29
So Carls new V-1 rebuild sounds great and kicks in much earlier then a stock v-1 would but the dam Gates belt sucks ass. It slips real bad in the higher range. The first night I took the truck out with a new gates belt before it slipped I saw 11psi at 4500 rpm then bam it slipped. I ordered a gator back from summit just waiting on it and a 2.50 pulley from Carl at 928motorsports. Im going to be making a video of it on youtube soon. It sounds even better than the superpowerdyne Carl did for me, and brings the boost in a hell of a lot earlier and harder than the BD-11 did. I ripped up a SS trail blazer pretty bad today LOL but the slip has to stop. I have new pulleys all the way round with a 7in crank a 2.62 blower all the idler pulleys are new from vortech the only thing that is old is the automatic tensioner and it looks to be in good working order there all 8 rib Im currently using the gates #micro-V AT 25-080790 a 8 rib 79 in belt and I will be going to a 2.50 pulley and a goodyear gatorback#4080790 and hope for better grip. Any ideas as to better grip would be great guys Thanks John
John,
I'm working on the pulley setup on mine too. The wrap pic above is mine.
I'm actually working on a new setup. Call ASP racing, get them to recess the water pump pulley for you and you can add a larger crank pulley.
They already have the design for the crank pulley, I've talked to them and they can custom make any size.
You'll have to move the water pump pulley back to clear it but it will work. I have a custom water pump pulley on mine now from them, waiting to see how big of a crank pulley i can install then I'll be able to increase the supercharger pulley and eliminate the slip.
Call ASP and they will hook you up. Just have them more or less notch the water pump pulley so it immediately turns back and then increases to the proper size right where the belt rides.
Get the bigger crank pulley and your done.
