F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
Old 10-28-2009, 01:03 PM
Vehicle: 2001 ford F150
Send a message via AIM to 01f1502wd
from wanting a procharger to Eaton M112
with a lot and I mean a lot of thinking, Im going to purchase a full swap Eaton for my 01 5.4. It is everything but the: alternator bracket, and a tensioner pulley. wheres a good place to get these? What else should I get to help with this install? Ive heard of upgrading injectors....I will post pics as we go along. and I will be getting a SCT xcal 3.
oh heres a link to what was discussed earlyier. anyone with a procharger?
Old 10-28-2009, 04:41 PM
Vehicle: 2003 Ford F150
You will need 42lb injectors and 90mm MAF Try http://www.buyfordracing.com/ Also, 255lph fuel pump. Then you didn't mention IC Heat Exchanger, brackets, pump and hoses. You can get alternator anywhere, bracket is FORD. Try used or MAD or FORD!
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
Old 10-28-2009, 05:42 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
I know we went over this and all, and the 2 cheap lightning swap kits are long gone
here's a post from your other thread...
Quote:
Originally Posted by tarajerame View Post
that's a whole 'nother can-o-worms on the tuning
I'll PM you who I use
here's the link for Mike Dunns site (and the list) the kit I PM'ed you about is supposed to be 100%
http://www.madenterprise.com/scparts.htm
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 10-29-2009, 07:57 AM
Here's one http://www.nloc.net/classifieds/show...ct/13195/cat/7
$1450, not mine and no affliation!
Old 10-29-2009, 10:07 AM
^thats just the charger. Im getting a FULL kit. so he has everything but the alternator bracket and pulley. although I dont know if he has the MAF or injectors im checking on that. where would I get the bracket and pulley. I didnt see any on buy ford racing.
Old 10-29-2009, 10:52 AM
Correct web site was is very limited but cheap for those things they offer. You can't beat them on that injector / MAF package. A caution on the MAF's as boost goes up and outside temperatures go down, most tuners would recommend a change to the MAF electronics to prevent saturation. Example and SCT2400 instead. For lower pulleys you can go on NLOC or NTHOC or Lightningrodder forums. For brackets, you obviously can go new with FORD, or you can find in salvage yards that might have an L or 2002/2003 HD. Believe it or not some of these vehicles have made it to the slavage yards. Surf the web for parts locators. I personnally got a rear end, heat excahnger brackets and the staggard shock bracket that way. If your talking about the idler arm, again salvage, MAD, forums. I bought my first alternator from MAD, but it stopped working so I went to my local Autozone and got a good deal.
Old 10-30-2009, 11:22 AM
Ive got the MAF, injectors, 255Lph fuel pump. like I said, I have the entire kit except alt. bracket and tensioner pulley. I just need to find where a good place would be to get them. I tried all the junk yards for and L's and they said no.
Old 10-30-2009, 11:46 AM
OK. For the alternator bracket, try MAD first then FORD. For the tensioner, I'm not sure what you are referring to. See pic. There is an idler braket that goes acroos the fron to front of the engine that controls the blower belt. It has 2 pulleys and 1 tensioer with pulley. MAD has theses or FORD. You don't see these much on the NLOC/NTHOC or Lighntingrodder Forums. You can surf the web for discount FORD dealers. The pulleys and tensioer might be bought form autoparts stores, but not the bracket. I can not find the part numbers. Hope this helps. If I missed the part, then let me know specifically what you need. MAD may be the easiest/cheapest bet. FORD can do, but indivuals tend to have a hard time getting discounts. Also, for that tensioer there is a spacer that needs to go on the front cover under the drivers side top stud, MAD has this or you could make your own. This aligns the mounting points for the idler bracket to mount to.
Old 10-30-2009, 12:06 PM
The MAD links didnt work. and Ill keep an eye out. I dont think spacers would cost too much.
Old 10-30-2009, 12:23 PM
Try http://www.madenterprise.com/catalog/F150.asp
Only need spacer on one of the attachments, there are 4 bolts that hold it on, actullay 3 studs and one bolt. Studs are already there, bolt is not.
Old 10-30-2009, 12:28 PM
Old 10-30-2009, 12:33 PM
and just to make sure were on the same page, its the one on the left with the square hole?
Old 10-30-2009, 12:41 PM
If I remeber correctly (not near truck), in the picture above, the top right has the spacer under the stud, stud is already there from factory. The bolt goes on the left side and it might be the lower one which can not be seen. There is nothing there from the factory (if I remember correctly). I've had the blower on for 55,000 miles now and I getting old.
Old 10-30-2009, 12:58 PM
ok. I will wait till I get it so I know what/where everyhting goes lol then ask more questions.
did you upgrade your tranny? heard of the "J-mod"?
Old 10-30-2009, 01:24 PM
I think the tranny gets a bad rep. I have a daily driver so all I did was install a shift kit. It did 2 things, increased overall clutch pressure and increased shift firmness which was selectable by changing/removing accumulator springs. Can't rememebr name but might have been Transco. J mod is an old term used for Ford Crown Vics and basically removed accumulator springs for crisper shifts.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
