F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
Old 10-22-2009, 07:01 PM
Vehicle: 2002 FORD F-150
i would like to do a lightning supercharger to my 02 screw 4x4 5.4- will this work w/ a 4x4 and what do i need to do w/ my tranny/transfer case to make it work ?
Old 10-22-2009, 07:45 PM
Vehicle: 2008 Ford F150
You shouldn't need to do anything. You'll have to have a custom program for your PCM to get it to work withe the larger injectors and MAF, but none of that effects the transfer case.
2008 F-150 Lariat SuperCharged SuperCrew 4x4
Old 10-22-2009, 08:45 PM
Vehicle: 2003 Ford F150
And you should already have the better transmission, ie the 4R100 which came with the Lightning.
Old 10-22-2009, 09:34 PM
Vehicle: 2003 Fast Screw
Quote:
Yes it will work with the proper computer tuning.
Your T case should be fine but you should beef up your tranny for the extra power. Most people at least add a performance valve body to the trans.
Unless you have a 7700 series F-150 which came with a 4r100.You will have the little 4r70w like I did. And it needs all the help it can get when you start putting some good power to it.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Old 10-23-2009, 12:22 AM
Unless you have a 7700 series F-150 witch came with a 4r100.You will have the little 4r70w like I did. And it needs all the help it can get when you start putting some good power to it.
Phil
Thanks Phil! Can you reccomend a good valve body to use and would it result in too firm of a shift? My truck is my daily driver.
Old 10-23-2009, 03:49 AM
For the 4r70w it is called a(valve body plat kit).
It will firm up the shifts but that is part of how it helps the tranny.
Quicker firmer shifts produce less friction and heat then the slow sloppy shifts that are common with the factory set up. Less heat = longer life of the trans.
There is information on this site on how you can change the springs around or something like that in order to adjust the shift firmness so it's not uncomfortable for DDs.
Mike sells one for 100 bucks and it's the one most go with.
Scroll down to transmissions. http://www.madenterprise.com/catalog/F150.asp
He also sells an installation kit for the blower intake assembly off the Lightning.(for the conversion). http://www.madenterprise.com/catalog/scparts.htm
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
