F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
Old 10-07-2009, 01:15 AM
Vehicle: 1998 FORD F 150
Knocklite: Interesting product
This looks like a reasonable safety item for boosted apps. Anybody seen or tried this, or something similar?
http://www.turboxs.com/more_info.php?ID=212
http://www.summitracing.com/parts/TXS-KNOCK/
Old 10-09-2009, 11:29 PM
JMC JMC is offline
Vehicle: 2000 Ford F-150 4x4
Send a message via ICQ to JMC
The Lightning PCM have the knock sensor turned off...... My knock sensor is mounted on the intake manifold because of manual transmission noise. The n/a engines use the knock sensor to remove timing or add it. Your light will be turning on causing you you to be worried while the sensor takes care of the problem. My truck has failsafe cooling so I don't need a temp gage. I have a speedo that I never look at. I have a wide band that I use for datalogging. I have a boost gage that is fun to look at. I should get a oil pressure gage because that is important. I use the tach to shift. A programmable shift light would be better. So IMHO it is a waste. But who am I to judge?
Regards
Jean Marc Chartier
4.6 to 5.4 swap, M5OD 5speed w/Modified Hurst short throw, Warn XD9000i, Troyer E-fans, Procharger @12psi, Troyer tuned. ;)
Swap notes; http://www.f150online.com/forums/art...ml#post3570245
Old 10-21-2009, 02:41 PM
Vehicle: 2002 Ford F-150
Send a message via AIM to Crash! Send a message via Yahoo to Crash!
It could be used for a tuning AID, but be aware JMC is right. There are known problems with powertrain noise triggering a Knock sensor. It retards timing, so if powertrain noise causes a signal, you lose HP, when there is no detonation or pre-ignition going on.
If you have a solid dyno tune, (11.8-12.6:1), you should have no issues, and not need it.
Old 10-22-2009, 01:51 PM
I tune my own, so I would like to have some sort of warning device. I thought this might get past the engine noise problem as it connects to the stock sensor wires. It would only be telling what the stock sensor is doing anyway, which can be datalogged.
Old 10-24-2009, 04:49 PM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
stewie (not sure of his user name on here) is running 21# of boost on his stock long block harley truck with a similar device
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
