F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
Old 06-13-2009, 11:25 PM
Vehicle: 2006 Ford F150
Quote:
Originally Posted by 05RedFX4 View Post
The 3v 5.4 will make a ton of power, as long as your internals will take it. Our biggest stumbling block is the trans in stock form with the stock converter, as rafa found out. I'm just guessing here, but I would think 500-525 at the wheels is about the limit for the stock trans. I don't know how much the built 4r75 will hold, rafa never came back to tell us.
My tranmission is already built and has an upgraded converter, so that's a moot point. So do you think I'm on the right track now going with the GT500 motor?
Old 06-13-2009, 11:33 PM
Vehicle: 2007 Ford F150 FX4
Yeah I guess so. Just keep us all posted on the details of the wiring and so forth. Once those engines become more available and cheaper, more conversions are bound to happen. We just need a pioneer to blaze a trail for us to follow.
2007 Dark Blue Pearl F150 FX4 Scab 248RWHP 309RWTQ on factory 20's w/3.55's
http://www.f150online.com/galleries/....cfm?gnum=5530
Old 06-13-2009, 11:37 PM
IIRC, rafa eventually had a 4v conversion done to his engine because he wasn't happy with the power he was getting. I think JDM did the 4v swap. You might want to talk to them for any tips.
Old 06-14-2009, 01:16 AM
Vehicle: 2007 Ford F-150
Send a message via AIM to pmason718
pics pics pics is all we need when you get this started
2007 Red Fire Metallic FX2 Sport
5.4 V8 3.55
Pioneer Z2 /w Bluetooth, XM Sat, & Nav Traffic
Alpine PKG-RSE2 Overhead Monitor
Alpine MRP-M450 Mono Amp 400w
Alpine MRP-F300 4ch Amp 50W
Q-Logic QL-C1FTX110 Custom Sub Enclosure
JL 10W3v3-2 Sub
Polk db571 Front & Rear Door Speakers
Hella LED tail and 3rd brake lights
4300k Digital HID's
23" Customize Saleen Wheels
Old 06-14-2009, 02:42 AM
Vehicle: 2005 Ford Lariat
Send a message via AIM to FX4 Matt
A built short block would be the way to go, less than 8k you can build a bad ass 5.4 3v and make 6-800rwhp its just silly to put that GT motor in your truck unless you got money to blow.
2005 6000#Lariat
Theres No Replacement For Displacement, 419RWHP/456RWTQ 13.6 1/4, Roush I/C Supercharger, 2lb lower pulley, XCAL2 "Dyno tuned by Mike Troyer", Stiegemeier stage 4 port, Pacesetter long tube headers, Magnaflow hi-flow cats & Xpipe, Dual Magnaflow, E-fans, GMS Coil Packs, Stull upper and lower billet grill, chrome halo headlights W/ HID's, HID fog's, Autospring 2" leveling kit, Viper 791XV, Line-X, Nitto Terra Grapplers, Chrome MB Blitz wheels, Dual heat exchangers.
Old 06-14-2009, 06:25 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
the wiring and tune are the least of your the issues with this proposed swap
#1 - what about the oiling system? you'd have to convert the gt500 block to a F-150 type? what about your steering? what steering are you going to use as you cannot use the F-150 set up (ask vinnie)
#2 - do a search, I posted the link to a couple F-150's that have done the swap and the amount of work involved
#3 - can it be done, YES
#4 - is it cheaper to get similar numbers from a 3 valve YES
#5 - can you do it YES but you better have some $$$$$$
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
Old 06-14-2009, 08:01 AM
Vehicle: 2008 Ford F150
Sean Hyland Motorsports has a built shortblock for $3,895 that would be good for 700 hp. There are a couple of rod options for more bullet proof rods and up the hp level to 1,200 and 1,600 hp.
2008 F-150 Lariat SuperCharged SuperCrew 4x4
Old 06-14-2009, 09:01 AM
I say do it. Anything can be done w/time, patience and some $$$. The GT500 motor w/a pulley swap and tuning should make for a "stupid fast" truck.
Sounds to me like you got a heck of deal and you should take advantage of it and get to work installing it in your truck.
Old 06-14-2009, 09:34 AM
Quote:
The GT 500 uses an iron block with a wet sump oiling system and has starter provisions already machined into the block. The Gt 500 block is vitually identical to the 5.4 truck block, it might be made from a stroger iron material but it is still a bolt in into any vehicle that had a modular v8 engine. You must be thinking of the GT supercar, that block had a dry sump system and no starter.
He may have to use the truck oil pan on the GT 500 block. Other than the pan, the oiling and steering are non-issues.
Old 06-14-2009, 11:24 AM
I originally was going with the build up of my existing 3v, but what I couldn't get my head around was all the custom made parts I would need to get larger power levels. For example, the supercharger I have now is made for this motor and I have maxed it out with available, off-the shelf parts. Whipple quit making the 2.75" pulley for it a few years ago, so I had to have one custom made. This wasn't such a big deal, but it would be just the start. A bigger throttle body would definately be needed, which would mean some kind of custom intake. Also, this S/C is just too small too generate any really big numbers-EFFICIENTLY. So, that means going to another, larger displacement S/C that was not designed for this engine, which makes for a lot of other issues. Then it hit me about the possibility of doing the swap. I have a modded GT500, so I know what they are capable of (mine currently puts down 654rwhp). With me not know anything about engine swaps/wiring, I have to ask if this is even possible, within reason, or economically feasible.
All I have to go on, at this point, is Rafa's build up. Didn't it take something like 7-8 months? Rafa was pissed and everybody was agreeing that it shouldn't take that long. Then JDM posted up their response and said that a lot of the delays were due to having to custom make parts in order for everything to work.
2006 Lariat 4X4
GT500 4V 5.4L Motor w/Kenne Bell S/C
BC Automotive 4R75W Tranny
Lund Racing Tune
628hp/555tq
3" True Duals
FAL 270 E-Fans
Ram-Air Hood____________
06 F150 5.4L 3V- For Sale
Whipple S/C- For Sale- 2.75" Pulley- For Sale
39lb Cobra Injectors- For Sale
95mm MAF Housing- For Sale
Dynatech LT headers- For Sale
Monster Box Tranny- For Sale
Kenne Bell Boost-a-Pump- For Sale
http://www.f150online.com/galleries/....cfm?gnum=8242
Old 06-14-2009, 12:11 PM
Why not do a roush drive snout conversion on your whipple then you can crank up your boost even higher. Another option is get a roush I/C intake manifold and put a whipple 3.4 for the lightning on it with the GT 500 rear plenum and TB.
Don't get me wrong, I'm not trying to talk you out of putting a gt 500 motor in your truck, I'm just trying to come up with some viable options so you can keep your current engine.
BTW do you still have the stock internals on your truck? How much boost do you have with the 2.75 pulley?
Old 06-14-2009, 12:47 PM
You've got my attention! I'm getting about 11.5 with the 2.75 and stock internal. Should be a little more boost, but the Dynatech headers do a great job. How limited would I be with the existing heads and the whipple 3.4?
I know what the existing aftermarket mods will produce on the GT500. For example, a Kenne Bell 2.8 on a GT500, can easily produce well over 700rwhp on pump gas. The big Whipple 3.4 can do even more and more efficiently because you don't have to spin it as fast. My baseline pull, before any mods at all on my truck, was 204hp if I remember correctly. That's about 100hp drivetrain lose. On a GT500, if you have the mods to get, say, 800 hp at the flywheel, that would be between 650-700rwhp in my truck. So, my question is, knowing the cost involved to achieve this crank hp on a GT500, what would have to done to my 3V truck motor to get the same results and at what price?
Old 06-14-2009, 02:31 PM
Forged internals at the very least. I read another thread where someone said that they used the stock lightning gasket between the S/C and the manifold on their roush setup on a 3v, so logically it would make sense that you can put any lightning upgrade blower on the roush manifold on the 3v engine. You may have to change the snout length because the roush manifold places the charger farther back than the lightning does. If you get a whipple 3.4 for the L with the GT 500 plenum and TB instead of the L plenum and have a custom snout length put on it you should be able to get 750 crank hp on a 3v with the right tune. Basically the 4 major things you will need, forged internals, roush manifold, roush or L pulley setup (bridge) and lower pulley, and a whipple 3.4. I'm guessing that all can be had for under 10K. Now a 3v will not make as much as a gt 500 motor with the same blower and same boost level because 4v heads flow more than 3v heads do, but it will make more than a 2v L motor will.
Old 06-14-2009, 04:32 PM
Vehicle: 200? FORD
ok, I was under the impression the GT500 needed similar mods to the gt supercar motor to work in a truck
Old 06-15-2009, 04:01 AM
Vehicle: 2005 ford F150
Send a message via AIM to Jwool15
Its so crazy that this thread was started because I was just thinking about doing the 4v swap myself the other day. I am highly considering it and want to do something unique that will make amazing power. My goal is to get the truck on the cover of Truckin' and it shouldn't be an issue. It's going to take lots of time and money but now that I have the new Dmax my truck just sits so why not finish it out. I got the complete saleen body kit with the 23 inch wheels. As some of you know my truck is blacked out in everyway possible. I want to keep the same theme but I am considering doing it flat black instead. The truck is going to be repainted because their is going to be lots of body mods done like completely shaving everything and doing some custom work. I dont want to give away all of the secrets. Lets just say I have a buddy who is a skilled body person that will be doing all the work for me. I'm going all out on this one, yall will all see when it is done. But who knows when that will be this is going to be a huge project but it is something different and why not. I am so psyched you have no idea, but sorry for the thread jack I am about to start a build thread in the 04+ section. I am just starting my research as far as motor options go so i'm going to do lots of searching and try to learn up on everything. Any suggestions would be helpful though guys!
Arent the navigator engines 4v's? What's the difference between them if so? You could always go find a wrecked navi and pull the motor and just completely build it for probably cheap. I also forgot to mention that I am going to be doing a custom twin turbo setup on this truck. We just got done fabricating a custom kit for an 04 mach 1 i'll post up some pics and specs in my thread. I'm going to do twin t57's
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
