F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
  #91
Old 07-02-2009, 03:34 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
crawl under the truck
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
  #92
Old 07-02-2009, 08:02 AM
Vehicle: 2003 Ford F150
Quote:
Originally Posted by 20Screw01 View Post
I have the factory L brackets but I am not seeing how this mounts to the factory location?
I can't see photo, but they the bracket bolt up with the inside bolts on the front bumper brackets. Those two brackets then attaches to a large bracket that should have come with the heat exchanger.
  #93
Old 07-02-2009, 01:56 PM
Vehicle: 2001 Ford F150
Got it thanks!
2001 5.4 Screw 4x4,6 inch trailmaster lift,Chickenears intake,Lightning grill and headlights,Autometer Tranny temp gauge,boost gauge Wideband A/F,Kanamari ram air hood,lightning motor swap,xcal3 tuned by Justin @VMP.
  #94
Old 07-05-2009, 12:50 PM
Vehicle: 2003 Ford F-150
Send a message via AIM to Z7What
You have the L H/E Bumper Brackets?
Wayne
2003 F-150 FX4 Powered by 2003 Lightning Engine #2005
AFCO H/E With Fans, Killer Chiller, Ported Throttle Body, Ported Plenum,
Ported C&L Elbow, Metco Idlers, 4# Lower Pulley, Bosch 255LPH Fuel Pump, 90MM MAF,
K&N Filter,EGR Delete, L&S Oil Separator, NGK TR6, Flex-A-Lite EFans, 170* T-Stat
Sooned To Be Tuned By Total Performance Solutions
Best 1/4 14.569@ 90.84MPH
Best 60' 2.08
  #95
Old 07-05-2009, 01:28 PM
Yes I have the one that holds the H/E.
  #96
Old 07-06-2009, 08:26 AM
There is a bracket that goes around the heat exchanger and then two small ones that mount that bracket to the bumper mounts. Go to the following site and you can see pics and part numbers.
http://www.nloc.net/classifieds/show...ct/11732/cat/7
  #97
Old 07-06-2009, 02:27 PM
I knew I was missing something I guess I will call ford today and see how much those are or fab something up. Thanks !
  #98
Old 07-06-2009, 06:35 PM
That is the bumper brackets i have been trying to say you need. I paid 48.83 a piece but i get very very good pricing at Ford!
Wayne
Best 60' 2.08
  #99
Old 07-07-2009, 07:45 AM
Normally you have to go to junk yard to pick these up. Some have made there own out of angle iron. I went to junk yard. Its was hard when I looked, but worth it if you do find. Having the right parts makes this swap really really easy.
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
  #100
Old 07-07-2009, 07:27 PM
How can you find these in a junk yard if they are a lightning part?
  #101
Old 07-07-2009, 07:45 PM
Get them from Ford
Heat Exchanger Bumper Bracket(Left) XL32-8C385-AA
Heat Exchanger Bumper Bracket(Right) XL32-8C384-AA
Wayne
Best 60' 2.08
  #102
Old 07-07-2009, 09:38 PM
Go to the nloc forum link above and you can buy them at a discount!!! See my post above.
  #103
Old 07-07-2009, 11:11 PM
Vehicle: 2003 Fast Screw
As usual,,,call Mike! He will get them for you for cheaper then you can go buy them at Ford! http://www.madenterprise.com/scparts.htm 510/742-6780
If you can find a Lightning in a junkyard then you might find them there.Otherwise forget it.
The ones on NLOC sold a couple days ago.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #104
Old 07-08-2009, 08:06 AM
Looks like ones on NLOC sold. Factory price $54 each. If you go on line and serach slavage sirtes for L/HD you can find for probably $50 for both. Or go to MAD and get a break on $54 each.
  #105
Old 07-23-2009, 02:02 AM
Ok finally at the end of the swap here but one last question. Where did you guys wire your intercooler pump into so it goes on and off with the ignition? Thanks for all the help on everything guys you rock!
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
