that's good to know on the i/c pump harness as I'm looking to upgrade my pump like the one over on timskelton's site
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon) old albumshttp://www.f150online.com/galleries/....cfm?gnum=8805
Thanks for the pics man and your truck is sweet! What did you do with your trans cooler ? Thats where I want to mount mine but i dont want it to heat soak the trans cooler...
Thanks Dave
__________________ 2001 5.4 Screw 4x4,6 inch trailmaster lift,Chickenears intake,Lightning grill and headlights,Autometer Tranny temp gauge,boost gauge Wideband A/F,Kanamari ram air hood,lightning motor swap,xcal3 tuned by Justin @VMP.
The tranny cooler is mounted above and does not interfear with it. Ford has the bumper mounting brackets which allows the H/E to be mounted where you see it in the picture, its the factory location.
If you can get brackets from the L/HD they mount to the same bolts on the frame as the bumper brackets and hold the heat exchanger in the opening of the bumper.
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
Got it I will use the L bracket and then just mount the tranny cooler higher right?
No, you dont move it at all!! The tranny cooler isnt in the way of the H/E. Just leave it where it is and buy the L/HD brackets from ford to mount the H/E in the correct place.
