F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
  #61
Old 06-22-2009, 06:55 PM
Vehicle: 2001 Ford F150
Anyone know where to get a cheap lightning throttle cable? 70 bucks is a little steep from ford...?
2001 5.4 Screw 4x4,6 inch trailmaster lift,Chickenears intake,Lightning grill and headlights,Autometer Tranny temp gauge,boost gauge Wideband A/F,Kanamari ram air hood,lightning motor swap,xcal3 tuned by Justin @VMP.
  #62
Old 06-23-2009, 08:15 AM
Vehicle: 2003 Ford F150
MAD might have done better. There is a guy on NLOC that taking his L apart. Did you resuse your speed control cable? If not then you will need a new one as well. Its just shorter, end is the same. Unlike the throttle cable which had a different end on it, at least mine did.
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
  #63
Old 06-23-2009, 01:15 PM
Called MAD yesterday and he wants 45 shipped so I will most likely do that. I did get the speed control box and cable so I am good there. Thanks for the help !
  #64
Old 06-23-2009, 08:47 PM
Quote:
I just did a L swap and had the same issue. I needed the L throttle cable and i wasnt paying what a dealer wanted, i thought it was $100 when i called but i could be wrong. I used the n/a cable and pulled the cable through the top of the pedal until it was tight and put two hose clamps on it holding it to the pedal. It didnt cost me anything and it is working. I stomped on it over and over trying to get it to come loose or slip and it hasnt. It has about 150 miles on it and 6 dyno pulls without an issue. I will post a pic in a few.
97 F150 MMR shortblock, KB 2.3, JLP plenum, JLP stage 3 Cams, Dirty Dog Performance 4R75, Blankenship tuned Eaton numbers 7.28 @ 95.8mph 1.62 60ft.
  #65
Old 06-23-2009, 09:48 PM
Heck ya post a pic will do that for sure its free!
  #66
Old 06-23-2009, 10:28 PM
All i am going to say is it works. I first tried zip ties but couldnt get them tight enough, so i used a hose clamp. I put two hose clamps on for safe measures and cut the zip ties off, i took the picture when i was still perfecting it. The zip ties are off and it is just the two clamps. I figured worse case senario both clamps magically break i still got 1/2 throttle to get back to the house on.
  #67
Old 06-24-2009, 09:08 AM
Sounds like it will if you can keep the excess inner cable secured. Problem is that at the throttle body side you have all this excess inner cable that NA throttlebody needs but L/HD throttle body does not. So the problem is not the overall length of the cable, ie jacket but the inner cable as it attaches to throttlebody.
  #68
Old 06-24-2009, 09:31 AM
Vehicle: 2003 Fast Screw
Spend the 45 bucks!
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #69
Old 06-24-2009, 10:30 PM
Vehicle: 2003 Ford F-150
Send a message via AIM to Z7What
Quote:
Originally Posted by phil6608 View Post
Spend the 45 bucks!
Phil
+1
Quote:
Didnt i get your the blower bolts? Want me to get a price on the cable to do it right?
Wayne
  #70
Old 06-24-2009, 10:54 PM
Dont remember the blower bolts but that would be great if you can get me a price on the cable. Just dont want to worry about it later but a good fix 150xlt...
Thanks Dave
  #71
Old 06-25-2009, 12:00 AM
Sorry the post above was directed to 150XLT about the blower bolts. I will call tomorrow and get a price. Anybody have a part number i cant seem to find it in my files.
Wayne
2003 F-150 FX4 Powered by 2003 Lightning Engine #2005
AFCO H/E With Fans, Killer Chiller, Ported Throttle Body, Ported Plenum,
Ported C&L Elbow, Metco Idlers, 4# Lower Pulley, Bosch 255LPH Fuel Pump, 90MM MAF,
K&N Filter,EGR Delete, L&S Oil Separator, NGK TR6, Flex-A-Lite EFans, 170* T-Stat
Sooned To Be Tuned By Total Performance Solutions
Best 1/4 14.569@ 90.84MPH
Best 60' 2.08
  #72
Old 06-25-2009, 07:34 AM
Nope not me, i got the bolts myself.
  #73
Old 06-25-2009, 08:42 PM
Also what do you do for a intercooler pump plug?
  #74
Old 06-25-2009, 09:25 PM
If you are refering to the electrical conection i used an injector clip. My tuner told me when i ordered the pump to not order the pig tail but to cut the injector plug off of an old harness and use it that it was the same. I had a few old wiring harnesses that i have collected and cut a conector off and it worked. It snaps right on, and it didnt cost me **** once again. I hope this helps and meets everyone's standards.
  #75
Old 06-26-2009, 01:18 AM
Perfect I like it! I have a spare harness so that works thanks !
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
