F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
  #46
Old 06-16-2009, 07:41 PM
Vehicle: 2003 Fast Screw
Not positive on this but I think the old one was 9 row and the updated one is 10 row.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #47
Old 06-16-2009, 08:54 PM
Vehicle: 2003 Ford F150
Should have 11 rows of fins again if memory is correct.
  #48
Old 06-16-2009, 09:27 PM
Vehicle: 2001 Ford F150
Here are the pics let me know what you think? I cant really tell but looks like 10 to me...?
2001 5.4 Screw 4x4,6 inch trailmaster lift,Chickenears intake,Lightning grill and headlights,Autometer Tranny temp gauge,boost gauge Wideband A/F,Kanamari ram air hood,lightning motor swap,xcal3 tuned by Justin @VMP.
  #49
Old 06-16-2009, 09:47 PM
What year truck did it come off of?
99 to 2000 are the ones they had problems with.
Looks the same as this 01 intercooler to me. And I count 10 rows.
http://www.nloc.net/classifieds/show...ct/11393/cat/7
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #50
Old 06-16-2009, 10:13 PM
This is off of a 2000 but I am wondering if there is a way to make sure its had the intercooler factory upgrade or (TSB) done?
  #51
Old 06-17-2009, 04:20 AM
Vehicle: 200? FORD
Send a message via Yahoo to tarajerame
the leaky ones had 9 rows and the upgraded ones had 10, it appears to be the upgrade but it needs cleaned for sure before it goes in, and that ladies and gentlemen is why you need to run an oil seperator
- '01 Procharged Lariat on a custom suspension w/ go fast mods - Tuned by Troyer (and a lil' something in the works)
- '03 Harley Davidson Edition -worlds first "Snake Bit" Harley Truck, shows in stock class,
- 'New Eddie Bauer Expedition - Tuned by VMP (boost coming soon)
old albums http://www.f150online.com/galleries/....cfm?gnum=8805
  #52
Old 06-17-2009, 04:31 AM
I cleaned the entire upper and lower intake,eaton and intercooler today and yes a oil seperator will be going on before startup. How do I find out for sure if this is ok? Just dumping a ton of cash into this project and need to make sure its ok...?
  #53
Old 06-17-2009, 08:20 AM
I think you could pressure test it.
But you have 2 of us now that agree that the bad one was 9 row and the upgrade has 10.
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #54
Old 06-17-2009, 12:58 PM
Just called svt and they said there is no way to tell unless I have the VIN from the truck it came out of so I think im just going to do a quick pressure test run it.... Thanks again guys!
  #55
Old 06-18-2009, 03:58 PM
Ok so I have found where everything goes except this? Do you guys know what this is? It looks like it connects to something on the bottom with that o-ring?
  #56
Old 06-19-2009, 08:12 AM
Can't see pics. If noone else helps, email me pics.
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
  #57
Old 06-20-2009, 04:44 AM
Ok so the motor is bolted in but I did notice that the L oil cooler does not allow enough space for a oil filer to go on. What is the fix for this ? filter relocation on remove the cooler? Thanks Dave
  #58
Old 06-20-2009, 07:49 AM
I guise that's up to you.
I can tell you that I have never had one on my setup.
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #59
Old 06-22-2009, 08:00 AM
As I rememeber the L oil cooler has the filter behind the cross member, so why wouldn't it fit?
Also, I believe you can just swap your non L filter housing on and use it instead.
  #60
Old 06-22-2009, 01:43 PM
The L oil cooler landed right on the front driveshaft so I removed the oil cooler and will use it down the road when I relocate the filter. Almost done with the install and then need to make a decision on the tune. Troyer ect...?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
