F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Thread Tools Display Modes
  #31
Old 06-12-2009, 09:31 PM
Vehicle: 2001 Ford F150
I dont have a L shroud can I use my stock fan and shroud if I fab the shroud to hold the H.E. tank?
2001 5.4 Screw 4x4,6 inch trailmaster lift,Chickenears intake,Lightning grill and headlights,Autometer Tranny temp gauge,boost gauge Wideband A/F,Kanamari ram air hood,lightning motor swap,xcal3 tuned by Justin @VMP.
  #32
Old 06-13-2009, 12:02 AM
Vehicle: 2003 Fast Screw
Only difference between a L and your stock shroud is the L has a little hole to bolt the HE overflow tank to. Your fan and the L fan are the same so ether will work with ether shroud..
Yes you should be able to rig your stock one and make it work.
Phil
Built Lightning block.
Stage 3 Ported heads. high performance Cams
Kenne Bell L upgrade blower 16 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #33
Old 06-14-2009, 02:13 PM
Ok couple of questions... Got the motor and everything looks good and I am going to take the eaton off and the intercooler to clean them and then install a oil serpator but how is it routed the best? I see the L&S is routed off of the fill tube but do I need an additional one on the pass side breather? Cant afford a L&S right now at 200.00 but want to put something on. Also do I need to install the eaton after I put the block in or can it be installed all at once? On a side note I am putting my NA motor in my brothers 2000 5.4 f150 (his is toast) and mine has a 4r70 and his has a 4r100 is there a reason for this?
Thanks again Dave...
  #34
Old 06-15-2009, 07:41 AM
Vehicle: 2003 Ford F150
Quote:
Not only is there the intercooler tank connection, but the fan on the L/HD sits further away from the engine for clearance and therefore closer to the radiator. Some have just cut down the shroud about 1 1/2 inches I believe.
  #35
Old 06-15-2009, 06:44 PM
Vehicle: 2000 Ford Expedition
As for the tune, i recently ordered a tuner from troyer (showing up thursday) and they gave me a SCT Xcal3 with 3 custom tunes for 500...pretty good deal if you ask me and it has only taken a couple of weeks for them to write it and ship it out!
Powered By Eaton
SCT Xcal3 tuned by Troyer
JLT Performance Ram Air Intake
2.5" true dual exhaust into flowmaster 40 series mufflers
20" KMC Rockstars w/ Blacked out centers
  #36
Old 06-15-2009, 07:44 PM
What do you think would be better a custome dyno tune locally or troyer? The local guys are force fed performance in Sacramento,CA and they want 800 total with tunes and the xcal3. Troyer is 500 I guess?
  #37
Old 06-15-2009, 08:00 PM
Talk to Jay at IVM motorsports in sparks
So I bought a 70k lightning motor complete for my 01 supercrew. I am now trying to think about what I will need to buy to complete the tuning ect.. I am thinking that it will need a tune and xcal? Does troyer or someone else have a tune that I can buy because I just dont trust anyone around reno,nv to do it.
Any help is appreciated and please let me know what else I will need...
Thanks Dave
Hay Dude try talking to jay at www.IVMMOTORSPORTS.COM 775-331-6577ort blvd in sparks. I know its hard to get a hold of him but hes done a lot for my expo blowerhat kicks ass doesnt over charge,and hes installing a snow stage 1 water/methanol kit and incorperating into my tune this friday i can show you my truck friday June 19th in sparks. I live in Elko and let me tell you theres no one around like Jay
  #38
Old 06-15-2009, 08:40 PM
Quote:
Thanks for the help man but I have had many terrible things realted to IVM with my friend and I. We race mustangs with nasa and he has put my friends mustang together like a rookie and someone who has no idea what they are doing. Example he brings a t45 to put n my friends 95 cobra that has a t5 and it will not accept anything else. I hope your truck is ok but there is no way I would ever take anything of mine to him.
Thanks Dave
  #39
Old 06-16-2009, 07:36 AM
The Xcal III is worth about $400 with basic tuning. So $500 is OK for supercharger, dyno should be more. Normally at least $300 to do 3 pulls without software changes, so $800 not bad. Woodbine did my last tune, since he drag races L's he has real world dyno experience. Dyno is nice, but not required. MAD should have some references.
http://www.woodbinemotorsports.com/
2003 F150 ExtCab/Step Side
Blown & Smiling Est 400rwhp/500rwftlbs
  #40
Old 06-16-2009, 07:47 AM
Wow,,I must be lucky.
Last time I was on a dyno it was $150. And we did 6 or more pulls!
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #41
Old 06-16-2009, 03:53 PM
Ok so here is the update, I have installed some ngk tr6's at .38 gap and now I am ready to clean the throttle body/intercooler and intake and then put the motor in. Can I install the motor with the eaton on or is it better to install it when the block is in place?
  #42
Old 06-16-2009, 03:57 PM
You'll have more room to work if you install the intake,then the blower after the block is in.
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
  #43
Old 06-16-2009, 04:00 PM
Sounds good thanks Phil !
  #44
Old 06-16-2009, 04:50 PM
Ditto.
In fact the damper needs to be off as well to fit in the engine compartment (if my memory serves).
  #45
Old 06-16-2009, 07:06 PM
Ok so just got off the phone with Mike from troyer (nice guy) and he said that I first of all need to check out if I recieved the intercooler factory upgrade so does anyone have any idea's where I can look at some pictures to compare mine to the upgraded one? I will get it apart today and post pics but just want to make 100% sure its ok...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
