ok i have a 2001 5.4l 2wd supercrew and wanting to add a s/c or do the lightning swap or possibly go with the troyer setup, after having it completed i am wanting to actually feel the power and be glad i spent the money i did and know that i have power under the hood. i will get w/e i decide to get installed and tuned by a shop that has a good rep.
also would like to feel the power right when i hit the throttle even at normal acc if possibly if not then somewhere around 1800-2krpm i would like it to kick in w/e is the best. also would like to keep decent gas mileage and not get only 10mpg
and as far as tranny what should i do about that will stock handle fine or upgrade and if so what, i currently only have 3.31 gears or 3.55's not sure cant rember, i plan to add 26" rims since its only 2wd so what gears should i go with as well
Go positive displacement blower if you want low rpm seat of the pants torque. See classfied for a great start. And yes you will feel the difference. Stay at 12psi or less with Eaton and a good tune. You probably have 3.55 gears. Lightnings had 3.73. If you go Lightning/HD swap, I have some instructions that orginally came from MAD Enterprises and I have modofied based on my experience. MAD is another good source of parts.
ok so if i have 26" rims which i plan to have same time i get the s/c still only get 3.73 gears or should i look for something into like a 4.56's or something
4.10s! at least!
Phil
Built Lightning block.
Stage 3 Ported heads. Comp Cams
Kenne Bell L upgrade blower 18 PSI
DMR Cog belt system
Kooks long tube headers
BTS race built 4R100 tranny
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
If you find an Eaton or another positive displacement blower to work with your truck, your torque will pull great with your stock gears, if you go centfifugal, you'll want the gears as your power won't start until you hit higher engine rpm's when compared to a positive displacement blower.
ROOTS OR TWIN SCREW=STOCK GEARING=GREAT PERFORMANCE
CENTRIFUGAL BLOWER=NO LOW RPM TORQUE=LOWER GEARS NEEDED FOR BETTER ACCELERATION=STOCK GEARING WILL MAKE YOUR TRUCK UNIMPROVED FROM 0-30 MPH.
Red 2001 4wd f 150 supercrew
5.4L Procharged D1SC, RR3" pulley
10lbs. boost@5Krpm. 317 hp/378tq.
Dynatech 1 5/8" longtube headers and flowmaster exhaust
Reason: because I'm Rick James
ok yea thats what i figured, as for s/c setup what is the best bang for your buck basically is what i am looking for and wanting to hopefully have around 350rwhp and 400ft if possible, wat the best way to go about that
and also i want low rpm torque and power gains i dont want to have to have it at 3krpms or above at the worst would like to have it kick in around 1800-2krpm or so, but would like it to be kicking it soon as i touch the gas, but will that hurt my gas mileage alot over something that kicks in higher rpms
so for instant power wats the best way to go
For a 2001 5.4 2V your best bet would be a Lightning blower!
With 26"rims,,you'll want 4.10 gears.
When you get on it it will hurt your mileage but if you can drive it normally you'll get great mileage!
Iv never been able to drive my truck normally since I put a blower on it!
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
ok so should i do a whole engine swap and tranny since i have 80k on mine or should i just get a tech cover or w/e and shift kit for the tranny to beef it up and just add the s/c to my stock engine, and if so wat kind of power number and times numbers would i possibly see
so if i got this wat else do i need to complete the s/c job
After that you will need a tune for the computer to make it all work.
You can put it on your stock block but if your going to want to make over 400hp you better get a built block!
With the stock pulley set up it should be around 350HP.
Phil
DMR Cog belt system
100 shot of nitrous
best 1/4 to date.
60' 1.68
11.76 @ 116.17
I run a centrifugal, have plenty of low end torque, see boost at 2000 rpms, run stock gears, and my 0 - 30 would be vastly improved if the truck wouldn't just smoke the tires.
so is that a better price on just the blower, and basically since i want low rpm power i need to look into something like eaton, and that link u gave me do superchargers only come with the blower and the top piece and not the bottom piece or wat,
basically tops i am wanting to spend is 5k for the s/c and install
lol ok man well whats the best supercharger bang for your buck i know i need a 70mm Throttle body get a 10psi pulley with the kit, 42# injectors, a 90mm MAf and a 255lph fuel pump, is what i have been told so to complete everytihng with that wat supercharger would you suggest thats the best bang for your buck
and wat all do i need to do to my tranny to handle the power
A L-truck swap would be the cheapest route if you can find a good deal. You wouldn't need a 70mm TB either...L-trucks use a much different style. As far as you transmission start looking for a Factory Tech plate, a deep sump pan, and a good aux. cooler.
2000 F-150, 5.4L, SuperCab, Flareside, ATI ProCharger
