Quote:
#1: what plugs are you running?
#2: you might want to check the bypass valve for leaks.
- IF you are using a SCT xcal2 or Xcal3. Talk to Mike Troyer @ troyer performance he has a good amount of experience tuning these trucks and he will probably be your best bet for a single email tune. Also Justin @ VMP Tuning He is a good tuner and I have purchased tunes from both. The other option and possibly the most cost effective is for your tuner to email you a tune that will be tweaked when you get there to the dyno.
- The plugs, injectors and MAf aren't hard to change I'd drive it salt lake then change them in the p-lot of the shop your going to have it tuned at.
I changed to motorcraft non platinum and 1 heat range cooler than stock gapped @ .035"
I've completely plugged off the bypass hoses in and out of the valve and gained less than a half of a pound. So it's working good as that was my first suspicion when the provided 3.7 pulley only gave me approx. 4-5 lbs.
I will change them at the dyno if I can't figure something out, I just don't want to reek of gas for the rest of the day while I'm out of town, but I certainly will if need be.
