I"m trying to find the right drive pulley combo for my Vortech. The stock 3.33" got me to 6 psi. A 2.95 gets me roughly 9-10 psi. I'm in the process of adding an intercooler so I want to get to about 12psi. To do this I would need to go to a 2.5" pulley which Vortech does not sell, the smallest they have is 2.75". I'm assuming this would be overspinning the supercharger if I went smaller than the 2.5".
Anyone know the proper calculation to determine the blower RPM's?
I'm assuming it would be engine RPM x the pulley ratio?
make sure you account for the loss in psi due to restriction of the innercooler
__________________ thanks to Dirty88 for the sig
- '01 Procharged Lariat on a custom suspension - Tuned by Troyer
- '03 Harley Davidson Edition - still stock and staying that way
- New Eddie Bauer Expedition - Tuned by VMP
Yep! Thats what I was trying to do, but I'm thinking the impeller RPM is going to be my issue now....looks like I'll be spinning it a little too fast with the 2.5" pulley.....may have to stick with the 2.75"....
I wasn't real impressed with 6psi, but I put the 9psi pulley on there for one trial run last night(hoping I didn't put a hole in a piston) and it was unreal! Can't wait to get the intercooler on and push it on up a little higher! Hope to get around 10-11 after the intercooler maybe....probably 9-10 is more realistic. But I've got long tubes and 3" exhaust so it flows pretty good, it's actually probably more boost than I'm registering due to less restriction.
2002 5.4 Supercrew
Vortech Supercharger
Dynatech Headers
Magnaflow High Flow cats
42lb Injectors
2600 SCT Big Air Meter
Factory Tech Separator Plate
Flex-a-Lite E-fans
Walbro 255lph Pump
Accel COP's
MotoBlue Connectors and Boots
NGK Plugs
Superduty Tranny Cooler
JLP Shackles
worked heads, long tubes anda free flowing exhaust allow you to make more power with less boost since your still pushing the same amount of air into the engine, sorry i dn't know what the stock 5.4 crank pulley size is, does your vortech use a seperate drive belt?
Lower is only one option, same diameter as stock .....I was worried about slip as you mentioned with a small upper. But the tensioner on this belt is unreal, it is almost all I can do to get the belt on there(and I aint a little guy).....so I hope it won't be a problem, no issue so far.
2002 5.4 Supercrew
Dynatech Headers
42lb Injectors
Flex-a-Lite E-fans
Walbro 255lph Pump
Accel COP's
NGK Plugs
JLP Shackles
I think a lower that fits on an L may work. If you are going to use an intercooler you will lose about two lbs of boost. You may also have problems with the BOV/Boost pass valve. I had a simular setup and had issues with surging at highway speeds. WOT was no problem
2001 HD,
Vortech SQ1 Supercharger
JLP Chip
Etched HD logo on rear slider
2in lowered, rear
L Tails
and 2003 HD
L Tails
1JT,
That looks exactly like what I'm going to do.... All the parts are on order.. What BOV did you use and why do you think your getting problems? Where did you locate your BOV? In your tune maybe? What size upper pulley are you using and how much boost are you seeing? Looks like the stock pulley.
2002 5.4 Supercrew
Dynatech Headers
42lb Injectors
Flex-a-Lite E-fans
Walbro 255lph Pump
Accel COP's
NGK Plugs
JLP Shackles
derrick929 try turboXS the 34mm racing BOV is incredible and increased my low end performance a good bit, if you experience any belt slip you can add an additional idler pulley and switch the tensioner to 100mm for more belt wrap. also I think riechard racing sells high traction / non slip head pullies
1JT nice trucks
1JT nice trucks
I've already got a Vortech Race BOV that I plan to install once I route all my intercooler pipe.
you should be fine with the vortech BOV. the BOV should be placed after the intercooler. I used 8 rib Reichard pullies and never chewed up a belt. do not go below a 2.9". I put a 2.75 w/a 6.75 crank pullie and overspun my sc and started blowing oil through my i/c and into my motor. which would not be a good thing. you can also have oil blow by. i had a breather installed on the driver's side of the motor and a retune and never had a problem with blow by.
