procharger 8 rib belt???
Originally Posted by jbravo316
My P1 procharger starts slipping shortly after I tighten it back up. I want more boost, but my tuner says it is spinning as fast as it can and be effecient. It shows 13 lbs or more, so what head unit would I need for about 15 to 20 lbs of boost depending on what size pulley is on it? Then I would sure want a 8 rib belt, or go to a cog system.
Certainly not spinning that blower anywhere near close to its max efficiency range. Going to a D1 or F1 head unit won't help unless you rebuild the engine and get the heads ported with some cams. Going to spend a minimum of $1000 to have you're P1 converted to a D1 and used head units are no cheaper. Boost isn't the issue as much as it is the CFM and there is a lot you can do before maxing out that P1.
The P1 might push a hell of a lot of boost in a little 4 banger, but would never spin fast enough for that to happen in my motor. Mine actually dropped 2 lbs of boost from stock to ported heads.
It looks like an additional idler - 2 - 2.5" - could be easily mounted at about 5 o'clock on the front of the Prochargers, either by replacing the mounting bolt with a longer one, or countersinking a bolt from the back. There is probably another 1 1/2" of wrap available there.
do you have a 3 core innercooler? eventually I'll have a superduty innercooler for my truck
CDB
Originally Posted by CDB03STX
Off subject, but how often should the P1's be rebuilt...bearings, etc.?
There isn't a schedule for them. If there is a problem it is usually a seal that can be easily replaced. Nothing else is user serviceable really. I just made up a phantom leak and sent mine back to ProCharger for them to check out before my warranty expired. Not a big deal as the P1's do tend to leak a little. The D1's supposedly have better seals and bearings but hard to justify $1000+ hit to upgrade.
Thanks, CDB
on
JMC
I can't recall who it is, but that has already been done...maybe Ganiman Whoever it is, say it's works well.
i guess I'll try to run a larger diameter lighting 8 rib crank pulley with a 6 rib belt (17psi pullied) and add an extra idler at the top, then install an external waste gate set at 14 psi before the innercooler to make 12psi into the engine about 3400rpms and hten it'll pull harder down low and still maintain the top end charge
