Go Back   F150online Forums > Powertrain & Mechanical > Superchargers & Turbochargers
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 05-11-2006, 09:04 AM
Garage is empty, add now
Vehicle: 2003 Ford F150
Prochargers w/ 4.10's come on in!
I am getting the procharger ready for install and have been contemplating a gear swap as well. I know for a centrifigal the psc-1 has good low end but I would like it ti really jump off the line. My rear tire is 31"o.d. and with the 3.55's and the weight of the scew it seems sluggish. My inlaws expy with the tow package has the 3.73's and even it feels more peppy off the line. What have your expereinces been with the 4.10's? Did gas milage suffer drastically? How is around town driving, which is 90% of what I do, we have my wifes Subaru for long trips.
Old 05-11-2006, 09:05 AM
Also, what did it cost you to get them swapped? I have the 8.8 rear-end.
Old 05-11-2006, 05:25 PM
adt adt is offline
Vehicle: 2001 Ford f-150 XLT
I switched to the 4:10 gears about a year ago and glad I did. Cost me around $1100. and yes you will notice the difference off the line, but it nots going to snap your head back, it is a 6000+# vehicle. Before, I cruised the highway at 75 mph and 2000 rpm. Now I'm at 2400 rpm. Gas milage didn't change much at all. Normal driving around town is no different than before. As for the P1-SC, you'll notice some gains at the low end but it'll really kick in around 3500 rpm. then yeehaa!! I never could understand why a full size truck would have anything else but 4:10's or better.
Click the image to open in full size.
http://www.f150online.com/galleries/....cfm?gnum=7238
Old 05-11-2006, 05:40 PM
Did the 4.10 help with the "sluggish" feel the stock set-up seems to have? Iknow it will nto be neck snapping, I just feel the stock gearing is flat out wrong. Dodges come with a 3.92 gear from the factory and feel much more 'willing' to accellerate than the fords do, even the ones that have the small 4.7l
Thanks for the comment on your experience.
Old 05-11-2006, 07:29 PM
adt adt is offline
With the 4:10 gears it won't seem sluggish anymore. I believe it's the right gear ratio for these trucks. The standard 3:55 gears are really more for easy cruising speeds and saving gas, not performance. I doubt you'll lose 1 mpg. The only problem is with more gidyup, the more you'll want to stand on it, thus using more gas.
Old 05-12-2006, 03:54 PM
Vehicle: 2005 Ford F-150
4.10´s
Guys, I have been looking to do this swap. I totally understand that for a better hole shot the 4.10 is the way to go. Who sells the pinion and gear set?? How hard is it to install??
Old 05-12-2006, 04:28 PM
What kinda gains can a guy expect at the track? 2-3 tenths.....
CDB03STX
Old 05-12-2006, 09:05 PM
adt adt is offline
Quote:
If you don't know exactly what you're doing, and you don't all the right tools, don't try it. The most important thing is setting the backlash properly. If you F that up, you'll trash your rear end. Not worth it. Just let an experienced tech. do it.
Old 05-12-2006, 10:19 PM
Quote:
1,100 Bucks seems STEP to me though. Gears aren't but 150-200 dollars or am I totally wrong here? If that's the case, I'll either be sticking with my factories or learnin how to set my backlash
CDB03STX
Old 05-12-2006, 10:29 PM
He has a 4x4 thus front and rear axles had to be done. I have been told to expect $4-500 including the gears and install kit for a 2wd truck.
Old 05-12-2006, 11:03 PM
Quote:
Sounds more like it...Duh, I didn't pay attention that the truck was a 4x4.
CDB03STX
Old 05-14-2006, 02:28 PM
WLF WLF is offline
Registered User
I did the install on my 2wd truck, here is the write up:
4.10 gear, Eaton LS install VERY LONG
The 410's do work well with the cent type blowers. I am running a Powerdyne. My experience with 430's showed me to stick with Ford Racing gears if you want quiet gears. I am running 31 inch tires.
Good luck and always have fun.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
