lowering kit f150 on 24s
Im new to the lowering scene as i have only ever installed ground force drop shackles . I think a 2/4 would look perfect but i am having trouble finding a 4' rear kit. For the front i think i am going to use the belltech adjustable struts . what are your thoughts, any help would be great
[IMG][/IMG]
[IMG][/IMG]
I'd go eibach or ground force. I have a ground force 2/4 coil/leaf drop and the eibach pro damper kit. Rides like a dream. Don't half @$$ it with beltech drop struts and stock coils. You'd have to do a flip and lifting shackle to get 4" drop and you'll bottom out your suspension a lot being on stock springs.
if i replace the leaf spring will that decrease my towing? I go to the mx track almost every weekend and pull a 22 ft boat during the summer. What about ford racing kits? i heard they were made by ground force . Also do you think a 3/5 would be to much ? i have 305 35 24 on the track right now . I just keep seeing way more 3/5 kits then 2/4 kits . I agree with you on not doing it half a** and want to do it right the first time
4" drop won't bottom.
5" maybe when towing or loading stuff..if not it's not bottoming.
2/4 kit and you can add helper bag if you tow, load often/long distance
3/5 or 3/4 can do, depend on your wheel offset.
18" or 24" doesn't change a thing.
wheel width, offset and overall tire(not wheel) diameter is what affect what can be done or not
24x10 6x135 ET: 30
I got that right off there website . does anyone have a f150 with a 3/5 on 24's or a 2/4? I really think 2/4 bc i do not want to bottom out , however a 3/5 would look sick . My front wheels stick out of the fender wheels about 1/2 inch , again i would not want to hit my wheel wells but want the best look possible
If you're tire are sticking out: you will rub.
30 offset isn't enough on 10'' wide to clear the fender.
305/35/24 is a 32,5" tall tire.
Mine are 32" tall(275/55/20) with the 3/5 drop and I rub the top of the inner fender on big bump/dip on fast road(45+mph)
4" rear won't bottom with pancake bump stop. (I don't bottom with 5" drop and pancake)
Stock bump stop are about 4" tall..lol
but it can while towing or loading unless helper bag.(which I have and tow my 7000lbs toyhauler(WD hitch) with ~1500lbs in the bed/tongue)
I have a 2/4 on my ford.
24x10 6x135 ET: 30
