Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Street Scene
Thread Tools Display Modes
Old 07-25-2008, 11:10 PM
Vehicle: 2001 Ford F150
Leak in Airbag System
To all you guys that have helper bags on the rear- How much air do your bags lose over time?
I have the Firestone bags and Firestone compressor and gauge kit and lose about 2 lbs of air over 24 hours. I can't seem to find the leak in the lines or fittings. I've tried pumping the bags up to 70 psi thinking it would be more obvious at higher pressure, then squirting everything down with soapy water, with no luck. Could one of the bags be leaking? If so, I would think that the system would leak down faster?? It's such a slow leak that I can't hear any air escaping. This really sucks! Any ideas?
Rob
2001 SuperCrew XLT 4X2
5.4L Toreador Red
http://www.f150online.com/galleries/...y.cfm?gnum=515
Sponsored Links
Old 07-27-2008, 12:32 PM
Vehicle: 2003 Ford F150
2lbs over 24 hours is a pretty small leak. If the airbags did have a leak.. you would know it by the sound of the kabooom. They dont just leak. Either its fine or it blows up. Probably just a loose fitting.
Old 07-28-2008, 02:50 AM
Vehicle: 2007 Ford F150
Yeah I have a small leak somewhere too. Probably about 3PSI a day or around there.
It's sort of annoying but not a big deal IMO.
2007 F150 FX2 Sport SuperCab 5.4l, 3.73 LS, 6.5' Bed
Magnaflow 16616 Catback Side Exit Before Tire
S&B Cold Air Intake
VMP Tuned XCal3
McGaughy's 2/4.5" Drop Kit
McGaughy's Rear Airbag Assist Kit w/ 3 Gallon Tank, Custom Made Control Unit
22" Boss 311 Rims with Toyo Proxes ST's 305/40R22
Leer 700 Series Tonneau, BedRug Carpeted Liner
Hella LED Tails, Hella LED 3rd Brakelight, Line of Fire LED Brakelight Strip
Old 07-28-2008, 01:20 PM
It's annoying me, too. I may redo all of my connections when I get time just to see if I can find it. It really isn't too big of a deal as I just bump the switch for a second in the mornings and put some air back in. I may call Firestone to see if maybe the compressor could be causing the loss. I wouldn't think it was normal seeing as how some people don't have a compressor. That would suck stopping by the gas station every morning to put in 2 lbs. of air.
Old 07-28-2008, 01:21 PM
Quote:
That's what I thought, but wasn't sure. Thanks for the info.
Old 08-05-2008, 12:45 PM
Vehicle: 1997 Ford F1FIDDY
some of the manual valves tend to leak at the valve itself. do u guys have check valves on the compressor leader hose?
Full Air Ride suspension done by M.I.C
Audio Courtesy of JL Audio and Rockford Fosgate
Old 08-06-2008, 07:52 AM
Quote:
Is the compressor leader hose the "output" line from the compressor? Where can I find a check valve and what do I need to look for.
Thanks!
Old 08-06-2008, 07:53 PM
Quote:
Thanks!
yes it is. the check valve for it should be screwed into the compressor head. then the leader hose is screwed into that.
Old 08-06-2008, 09:17 PM
After looking a little closer at the check valve idea, it seems that the compressor does have one on the outlet. However, there is not one near the gauge/switch and I can see where a leak could occur there.
Old 08-07-2008, 06:49 AM
i have these before my valves. keeps the air from the bags from bleeding back into the tanks when the tank is low.
http://suicidedoors.com/SMC12CheckValvewithFittings.php
it also helps me pinpoint leaks in my system. if i leave my truck aired up at night and i see it drops below certain psi. i know the leak is somewhere from the bag fittings or the valves themselves.because it wont bleed back into the tanks with the check valves in place.
now if i leave the truck aired up and stays up all night and my tank is empty. i know the leak is behind the check valves.
i know it sounds confusing lol...best thing to do is redo the fittings. instead of using teflon tape..try using the liquid teflon. best sealer out there.
Old 08-07-2008, 10:34 PM
Thanks for the info Slammed! I'll hopefully have a chance to troubleshoot soon.
Rob
5.4L Toreador Red
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
