Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Street Scene
Thread Tools Display Modes
Old 06-23-2008, 05:06 PM
Vehicle: 2007 Ford F150
Drop install tips or pointers?
Well I have an 07 FX2 Supercrew with newly installed Boss 330's black/chrome, and my eibach 2"-3" kit will be in this week. I'm going to install the rear springs myself, and I was wondering if you guys had any helpful tips or pointers on the install ie. moving the gas tank? I have a shop installing the front springs, and doing the alignment.
Sponsored Links
Old 06-24-2008, 06:37 AM
Vehicle: 2008 Ford F150
I helped a friend put that very drop on his FX2 a few months back. You may want to see about having the other shop change the rear springs out too. In order to get the front bolt out of the left side spring, you need to drop the gas tank; or cut the bolt. We went the bolt cutting route, and went through about 3 sawzall blades in the process. Another benefit to having the shop do the rears is that, when done prior to the front end alignment, they can set the front end up correctly-it would need to be redone after the rear is lowered as camber would change even as the rear suspension is lowered.
Old 06-24-2008, 11:13 AM
Vehicle: 2006 Ford F150
I used a hacksaw to cut off the driver side forward leaf bolt. I took the nut off and tapped the bolt inward towards the tank enought to get the saw on the shank. It was all down hill from there. It costed about $12 for a replacement bolt. Not having to remove the tank, saved a ton of time. I also installed the front springs and had the front end aligned at a shop. I rented the spring compression tool from Autozone to do so. I found the front was much harder than the rear although I read where other people thought it was easier. Good luck with your project.
2006 Lariat Supercrew
Roush Intercooled Supercharger, + 2lb pulley, Duals - Magnaflow Tru-X Muffler, 4.10 Precision Gears, FAL 270 E-fans, Troyer Tuned
Eibach 2/4 drop, Roush Chin Spoiler, HD Grille, P.E. Tonneau Cover, 22" AR Razor 6 Wheels, 285/45-22 Toyo Proxes S/T Tires
Old 06-24-2008, 06:16 PM
Vehicle: 2004 Ford F150
CUT CUT ! I put an Eiback 2/3 on my 04 and did the same thing with a sawzall and about 4 blades. I cut both sides because the fuel tank on one side and muffler on the other side were both in the way. After that it goes pretty fast. Bolts and nuts are pretty expensive from Ford but you can get a local frame and spring shop to set you up with good grade stuff at half the price.
Have fun !
Old 06-24-2008, 06:44 PM
Vehicle: 2003 F-150
I helped on the install on the 3" springs, we moved the gas tank.
Just unbolt the filler neck from the bed side, and slightly lower the tank and take the straps loose, and move it around as needed. It can slide any direction about a foot. Just be careful. We had a 4' long 6"8" piece of wood under it to support the full length of the tank.
Front camber should not change much after doing the rear. Only thing that should change is caster, which is a non-wear angle.
Just do the rears first, take it to the shop, have them do the fronts and alignment. But honestly the fronts arent that hard to do. Actually easier then doing a spacer install i believe.
Jmod
... 3/5 Drop... Tint 15%F 1%R... Dynomax Bullet Dual 16" Efans
P&P TB/Plenum... L HL/Corners... Custom Sub Box Reverse Fogs
jamzwayne : I'm not saying dont get any hoopie patch for your dang-dang
scott1981 : Fly your American flag, but dont let it block the view of your toyota.
gators241987 : Chris Hansen is a coc.blocker
jbrew : 5fours are notorious for leaking up front @ the water jackets
Old 06-30-2008, 11:58 AM
Thanks for the input everyone. I was notified that my kit is on backorder, so now its just the waiting game.
Old 06-30-2008, 12:45 PM
Vehicle: 2007 Ford F-150 FX2
Quote:
x2
i ordered from autoanything.com, and mine is on back order until the end of the week or beginning of next week...
Old 06-30-2008, 09:39 PM
I've got some tips in my drop thread here about taking the rear leafs out and a little bit on dropping the gas tank. I have a flip kit so it may be a bit different, keep that in mind. And to be honest the front springs weren't that hard to switch out.
2007 F150 FX2 Sport SuperCab 5.4l, 3.73 LS, 6.5' Bed
Magnaflow 16616 Catback Side Exit Before Tire
S&B Cold Air Intake
VMP Tuned XCal3
McGaughy's 2/4.5" Drop Kit
McGaughy's Rear Airbag Assist Kit w/ 3 Gallon Tank, Custom Made Control Unit
22" Boss 311 Rims with Toyo Proxes ST's 305/40R22
Leer 700 Series Tonneau, BedRug Carpeted Liner
Hella LED Tails, Hella LED 3rd Brakelight, Line of Fire LED Brakelight Strip
Old 07-07-2008, 01:17 PM
Quote:
Originally Posted by Spaceman Spiff View Post
x2
Yeah, thats what they told me, and then the guy said realistically 2 months. . He told me to call to make sure it was in stock before I place the order again.
Old 07-07-2008, 01:19 PM
Why is there a carrier bearing relocater in some of the kits, but not in others? Is this something that I will definitly need?
Old 07-07-2008, 01:50 PM
from what i have heard, some of the trucks have a two piece drive shaft, and the drop causes a vibration with out the relocation kit. mine has a one piece drive shaft, so i am not so worried about it.
i just sent another email to see if it is in stock yet. i never cancelled my order because they had a one day only 15% off sale, so i only ended up paying $266 for the kit. cant beat that!
Old 07-07-2008, 01:52 PM
Vehicle: 2003 F-150
correct. This relocation is kinda a PIA, more IMHO then the rest of the install. Its alot of measuring, and using poor printout stencils
abelrob: if you want I can help with the install up in Austin if you want to make the drive out here
The carrier bearing is used on 2 piece drive shafts. If you have the 1 piece drive shaft you won't need it. If you have the 2 piece, you'll need it.
Old 07-07-2008, 03:19 PM
When I get my kit, I might just have to take you up on that offer.
I only have a one piece driveshaft so it looks like I wont be needing the cb relocater.
Old 07-07-2008, 03:22 PM
Damn, $266 is a hell of a deal. Will you do me a favor and let me know when they ship it out?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
