Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Street Scene
Thread Tools Display Modes
Old 06-10-2008, 08:04 PM
Vehicle: 2003 Ford F150
Hey you Baggers
Well ive finally made the decision to bag the rig. Since ive got it down to the frame right now its the best time to do it. But just like everthing else i want my setup to be diffrent than just a kit. Im not a master fabricator. But, i can make due.
Here is my little problem i have in the setup id like to do. I want to keep all the link bars and bags inside the frame. Reason for this is i want to stuff a big "fatty" rear tires on this someday. So the airbar kit wont work. I got basically no experience setting up suspension componets. But i have a good grasp on what needs to be done.
Anyone got some helpfull tips or experience in this sorta stuff?
Sponsored Links
Old 06-10-2008, 09:38 PM
Vehicle: 2004 Ford F150
look around at www.streetsourcemag.com Check out the owners profiles/readers rides, look at their pics and get an idea of how you want to set it up. That will help you tons!!
Old 06-10-2008, 11:04 PM
pretty nice. i think i could only find one F150 that showed his setup in the rear. Got any good sites for 4-link bars,bags. that sorta stuff?
Old 06-10-2008, 11:35 PM
www.kplinks.com
www.suicidedoors.com for air management
Old 06-10-2008, 11:43 PM
im ready for the cutting aspect of it. ill go just low enough to sit the frame on the ground. Wont be any dragging. more than likely i will have to cut up the bed maybe not so much the inner fenders. dont know yet.
Old 06-11-2008, 01:03 AM
i wouldn't run the bars inside the frame... simply for stability reasons. the idea of the wider the stance, the more stable it is applies. if you were thinking about running a wide rear tire, you may have to shorten the rearend. that way you can keep the bars outside the frame, and run wide tires.
Old 06-11-2008, 06:35 PM
eh your probably right. Now i just gotta start saving up so i can start buying all the parts needed.
Old 06-11-2008, 06:44 PM
Vehicle: 2005 ford f150
Quote:
but still would be limited on the width of the tire because of the 4 link, cuz he could get custom wheels with alot of back spacing instead of shortening the rear end but i like a nice deep wheels as do many others
but if you really want some wide rear tires find the tires you want and then build a new back half of the frame so that there is room for the bars outside of the rails
btw i just ordered a universal 4 link from suicidedoors.com itll be here friday but unfortunately its not for the f150
my gallery on photobucket
Old 06-11-2008, 06:46 PM
Vehicle: 2003 F-150
Yay!!!!!
I agree buy the tires and everything you need and build around them
Jmod
... 3/5 Drop... Tint 15%F 1%R... Dynomax Bullet Dual 16" Efans
P&P TB/Plenum... L HL/Corners... Custom Sub Box Reverse Fogs
jamzwayne : I'm not saying dont get any hoopie patch for your dang-dang
scott1981 : Fly your American flag, but dont let it block the view of your toyota.
gators241987 : Chris Hansen is a coc.blocker
jbrew : 5fours are notorious for leaking up front @ the water jackets
Old 06-11-2008, 06:55 PM
bagger
Old 06-11-2008, 08:11 PM
Well i did some measuring a while ago and it is possible to fit a 12" wide rim between the body and the frame. about 4 inches to spare. so there might be enough room for the 4 link bars. it will be close.
Im considering this http://www.kplinks.com/product.php?p...&cat=51&page=1 seems pretty good for the price and shouldnt require to much fab to install it
and love the pic!
Old 06-14-2008, 03:11 AM
Vehicle: 2002 Ford F150
Can't go wrong with the KP Kit. That's what I'm running, but the the one with the cantilever.
Old 06-14-2008, 12:20 PM
what kind of air management kit are you running? Switches or digital?
Old 06-14-2008, 05:52 PM
Quote:
(3) VIAIR compressors, 2 (5) gallon tanks, no pressure switch, manual switch for compressors, ½" lines, 8 valves, 4 switches (1 for each corner) my pedal adjustment switch was converted to a pancake switch & a Dakota Digital gauge that displays all 4 corners and tank pressure on a single 2 1/16" gauge.
BTW, I like the idea of going with a larger wheel in the rear.
I'm actually having some staggered fit wheels being machined right now, but they will only be 10" in the rear (with more lip) and 9" in the front.
Old 06-14-2008, 05:59 PM
damn 3 compressors? i was figuring just running two. And two 5 gal tanks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
