Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Special Interest > Street Scene
Thread Tools Display Modes
Old 05-09-2008, 03:21 PM
Vehicle: 2004 Ford F150
Dropping my 04
Hey All ,
After moving the 1200+ miles from Texas to Ohio and tripping over lowering kit boxes in my garage for the winter I finally got the time to put the Eibach 2/3 kit on my 04 F150 SCAB 4X2 tomorrow !
One thing I wanted to make sure of on the front end ....
Do I take off the tie rod end AND the sway bar link to get the full front end dangle (FFED ) so I can pull the strut assembly out ?
Thanks ... Blaise
Sponsored Links
Old 05-09-2008, 03:26 PM
Vehicle: 2003 F-150
sway bar yes, tie rod no
based on my previous experience
Jmod
... 3/5 Drop... Tint 15%F 1%R... Dynomax Bullet Dual 16" Efans
P&P TB/Plenum... L HL/Corners... Custom Sub Box Reverse Fogs
jamzwayne : I'm not saying dont get any hoopie patch for your dang-dang
scott1981 : Fly your American flag, but dont let it block the view of your toyota.
gators241987 : Chris Hansen is a coc.blocker
jbrew : 5fours are notorious for leaking up front @ the water jackets
Old 05-13-2008, 10:00 AM
Hey Patman,
Thanks for the reply.
Turns out that the Eibach kit went on really easy with only a few small issues. I wound up taking the tie rod ends out of the hub assembly and leaving the sway bar hooked up. The strut came out with no problems at all. I put some before and after photos in my gallery.
I did have to buy the caster, camber adjustment bolts (lower control arm) to get things back into alignment.
I had read that when doing the rear leaf springs the front spring bolt on the drivers side needs to be cut or you have to drop the fuel tank to get that bolt out ... yep .. thats true, but I figured it would be quicker to cut the front spring bolt on the passenger side as well because the muffler was in the way. Those bolts are about 15 dollars each from Ford and the nuts were 11 each ! I ended up getting good high quality coated grade 8 replacements at a local frame and spring shop that does work on commercial trucks. They had the exact sizes and I paid around 20 bucks for both sides.
Next ... I think I will try a sway bar for the rear and a thicker one on the front. The truck corners better but still has a little more lean than I want. Anyone have any reccomendations on which ones to use ?
Old 05-13-2008, 01:42 PM
Moderator &
Vehicle: 2005 Ford F150
Congrats on the drop.
Funny, my local TSB got mine back in alignment without any camber bolts.
Texasblaze, BTW, your little camera icon doesn't link to your gallery.
Quote:
Originally Posted by Habibi View Post
I love Quebec.
Old 05-13-2008, 02:15 PM
Hi Stealth,
Thanks ... not sure why mine had to use them and yours didn't .....
Fixed the gallery link .. appreciate you lettin me know
Old 05-13-2008, 02:21 PM
Moderator &
Link works now. Nice truck!
I love Quebec.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
