Accually i wired it into the unlock side of the lock mechanism. 1 touch driver door 2 touch both door's. Yes a big problem with that was the stock wiring. Accually the wiring wasnt too much of a problem, but the stock fuse was. The stock fuse was alright for operation of just one silenoid at a time. But, use of both at the same time would blow the fuse. So, what does everyone do? put in a bigger fuse
walla fixed.
Also another problem was the lock mechanisim inside the door. say if you got out of your truck and accidently locked it with the remote or the manual push down on the door lock by the window and shut the door. When you went to open your door with the silenoid the lock would win. And it would be time to break some glass.
I opend up my keypad for the remote lock and perminatly disabled it so i wouldnt accidently lock the doors by habbit. And since there is no door handle its completley usless anyways. Second i went back inside the door and made sure that i couldnt lock it manually. So basically i have no locks.
Installed a couple springs to kick the doors open and it works like a charm.
Most people would frown upon just using a bigger fuse. but since the silenoid activates and stop so quick. it would take alot more than that to "burn down" the electical wires.
The best part is. I didnt have to run any wires at all!
