2013 sony system upgrades
#31
So I planned on making some kind of relay setup to create an amp turn on signal until I found a wiring diagram for the sony amp setup and lo and behold there is a real 12v turn on signal going to the amp. So I tapped into that signal to trigger the audiocontrol processors and both amps. My system has been installed and running for over a year and its flawless. I've had absolutely no problems at all.
#32
If I had to do it all over again, I would just get the kicker VSS (vehicle specific system) setup and some better speakers and call it a day. Kicker makes 3 different models of the VSS for 2009-14 150's, and this one works with sony and My Ford Touch system. Best part, it's plug n play, no cutting and splicing wires.
http://www.kicker.com/PF150C13
It's pricey, but in the end it's cheaper than what I did.
#33
http://www.ebay.ca/itm/09-14-F150-SU..._qi=RTM2067267
It seems to pretty much be the same as the Kicker direct system, but much, much cheaper. I think I can get a bit more by just upgrading the speakers and leave the Sony amp.
#34
After reading all you went through and trying to find just a bit of an upgrade over the stock system, I'm going to go for this...
#35
#37
I ordered up the sub and just waiting on a few more pennies to order up some speakers. I think I'll just leave it at that for now. Maybe I'll run a processor and proper amp to the speakers sometime in the future, but from what I heard in my buddies truck, I may be fine as is.
I had a 3000w+ system in a couple of my older vehicles(2 batteries, massive capaciters, 0 guage wire,etc.), I just don't see the need for that anymore. I would rather spend the coin on other upgrades for the truck...
#39
I know this is an older thread, but I have a question.
I have a 2014 FX2 with sony nav. I had a local shop install the AC LC7I, JL-5/700 amp, JL C3 570 components in the front, Some Alpine SPR 68 in the rear and a custom sub box I built to fit the JL TW3 10" sub. Very happy with everything except one thing. How do you adjust the ringer for incoming calls, if your not quick to turn the volume down on incoming calls it can be brutal.
#40
I don't worry about it, I Don't have a phone connected to the system. After playing with sync on previous vehicles, I found it's quicker and easier to just do everything manually. It takes roughly 30 seconds and several voice commands just to adjust the temp or you can reach down and turn the **** manually in about a second. Sync is just a worthless gimmick that helps ford sell cars, but in reality it's just a pain in the butt.
And before you ask, I don't answer the phone when I'm driving. It goes in my pocket and stays there until I get where I'm going. My life and others on the road are more important than a damn phone call.
#41
I checked your link and it states, "Not compatible with Sony or base audio systems."
