Go Back   F150online Forums > Audio & Video System > Speakers & Subwoofers
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Thread Tools Search this Thread Display Modes
Old 02-21-2012, 10:48 AM
1998 Ford F-150
Vehicle: 1998 Ford F150
Paul Morck GoodOlBoy711
Questions about Speakers, Subs, Wiring, Etc? Read Here
Well, I thought I would write up this thread to help people with any questions they may have regarding their car audio install. Note, this doesn't cover everything but should help a lot of people new to this area when they go to do this. Also I definitely don't deserve all the credit for this, as a lot of the information you'll find in here I learned both from members of this site and others.
If this is the first time your doing an install, you need to know one main thing, no one's first install goes perfect. This is a learning experience in both the way you do and what parts you use. I say that because doing the work one way may not be the best way for another person. And also when it comes to car audio the sky is the limit price wise, you could spend $100 to do a simple upgrade, or $10k and go full out competition style. Everyone's style is different so you need to find out what works best for you.
Okay, let's get to some basics:
Door Speakers
Quote:
These come in many shapes, sizes, and types including:
  • Tweeters
  • Midbass
  • Coaxials (2-way)
  • Triaxials (3-way)
  • Round
  • Oval
  • 4x7's, 5x7's, 6x8's, 5.25's, 6.5's, etc.
So which one is right for you?
If your looking to just do a factory upgrade, not do any modification, or have a blown speaker and just want to replace it I'd recommend a set of decent coaxial/triaxial speakers. They'll play better than the factory door speakers, and you generally don't need an amp to bring out their full potential. Also as plus they're available in factory sizes so it's just a simple bolt in swap. If you don't know what your factory size is, get on crutchfield and use the outfit my vehicle tool they have, it'll tell you what size your speakers are.
Okay, so you don't want to do just a basic swap, your looking to amp up your system some?
I'd definitely recommend a set of component speakers. What are components? These consist of a tweeter, a midbass, and a crossover. These work by using the crossover to only send certain signals to each speaker. This helps cut down on distortion and allow the speaker to play more clearly because it won't send the speaker frequencies that it doesn't like to reproduce. However to get the full potential out of the speakers you need to power them with an amp, and deaden the doors. (More on this down lower)
Subwoofers
Quote:
So now your ready to add some low end to your vehicle? Subwoofers are great because they'll fill in the frequencies that door speakers can't reproduce without severe distortion. Or if you wish, they'll give you that ground shaking bass that'll wake the neighbors and make you do a hair trick. This area is a lot of personal preference, whether you want a simple sq (sound quality) setup, a decent daily driver system, or your going for numbers with a spl (sound pressure level) setup. Subs, like door speakers have many different configurations also including:
  • Round, Square, Oblong, Etc.
  • Single, Dual, or Quad Voice coils
  • 8" all the way up to 21" (maybe even bigger)
  • 1ohm, 2ohm, 3ohm, 6ohm, 8ohm, etc.
So what's right for you? If you want a sq setup I'd recommend going with one or two 8's or 10's sealed. They'll be able to pick up where your midbass leaves off, and still be able to hit most of those lower frequencies. A single 12 sealed could also work, but the main thing in a sq setup is you want all the sound to blend, so you don't want the bass to be overpowering the highs.
You want a decent daily driver where it's not overpowering but something you can still show off to your friends to make them think your cool? This is where it gets tricky. A decent set of 8's or ten's ported can definitely give your friends that wow factor, however you make sacrifices going ported (more on this later). Or a set of 12's sealed can give you a great daily driver system that would love to be shown off, or even a single 15.
So you just wanna pull numbers, demo your vehicle, or shatter your neighbors windows? First of all, definitely go ported. Now here is where size of the sub doesn't play as big of a difference. For the other setups, different size subs can have difficulties reproducing certain frequencies. But when you go ported, you tune your box to your subs optimal frequency (Generally around 32Hz). Don't forget to factor in cabin gain though, our trucks act as like a bigger box that your's is inside of when ported and it'll give you a more peaky response between the ~28 to ~50Hz area, which means it'll be even louder.
No matter which way you decide to go, you'll definitely need to put an amp to the sub to push it.
Subwoofer Boxes
Quote:
So what box is right for you? Well what kind of music do you listen to and what kind of setup are you going for? If you want a sq setup then like stated above definitely go sealed. If you want a spl setup then definitely go ported. But say you want a daily driver setup, then what? Well this can usually be answered by the type of music you like. If you like rap, techno, or songs with heavy bass and you really want to bring it out then I'd say ported. If you like rock, country, or styles around there with tighter bass then I'd say sealed.
Well what's the difference between ported and sealed? Ported is tuned to a frequency to optimize around that area, meaning it'll play a lot louder there. But as you move up the frequency curve generally around ~50Hz, there will be a sharp roll off where the other frequencies will almost sound muted compared to the low ones. Sealed on the other hand provides a smooth curve through the frequency range so it plays more evenly, the sacrifice to this would be the amplified low notes you get in ported.
Amplifiers
Quote:
Okay, so now it's time to apply power to your system, to really give it that extra kick it's been begging for. So how do you know what amp to use? Well theres a few different types of amps too, including:
  • 1, 2, 3, 4, 5, or 6 channel
  • Class A, A/B, D, G/H
I generally suggest to choose your speakers first, and then try to match an amp to the specs of the speaker. Well how do you match your amp? Your speaker whether it be a sub or door speaker has both a rms wattage rating and an ohm rating. You'll notice most amps can put out more rms power at a lower ohm load. This is because there's less resistance between the speaker and the power. However there is some amps out there that do constant power no matter what the ohm load the amp is seeing. Also I suggest choosing an amp that can produce about ~100rms or so more than what the speaker is rated at so you can cut the gain back to prevent clipping.
Now onto the classes of amps. This can get very technical so I'm just going to sum it up in basic terms. Generally class A, A/B, or G/H are used for door speakers because they can produce "cleaner" power to help prevent distortion where it would be highly noticeable. Class D amps or Mono block amps are generally used for subs where they can produce raw power and where distortion is barely noticeable.
Sound Deadening
Quote:
Deadening a vehicle can greatly improve the sound quality of your system. If you go with components in a door, the deadening is a must otherwise you'll be losing precious midbass response. Now there's two main kinds of deadening both which do different things. These are cld tiles and then mass loading barriers. CLD tiles are used to help with vibration and bring out speaker response. Mass loading barriers are used to help cut down road noise, basically they're adding material to panels to block out sound in a simple way to state it.
Well that's all I have for now, and I still feel like I missed a lot but it's a basic overview that might help some people. Later on I'll touch on head units, but for now I have class haha. If there's anything you feel needs to be corrected or other sections I add feel free to give me some insight!
Old 02-21-2012, 02:28 PM
Garage is empty, add now
Vehicle: 2009 ford f150
Thanks Pizzaman..
great info thread....should be enough to get anyone started in the right dirrection.....
www.f150online.com/forums/members/gtullous-albums-my-09-platinum-picture150260-t1.jpg
2009 F-150 Plat.
magnaflow catback
305/60/20 Goodyear Silent Armor
A.R.E. topper
Pioneer AVH-P4200dvd
Nav and Sirrus module
JBL MS-8
Old 03-04-2012, 07:12 PM
Awesome!!! I'm starting to look into building my first complete system for my Screw and this will help! Thanks!
2003 S-Crew FX4 Lariat
3.73s (4.88s on way) | AF1 | Custom Dual Exhaust | Fabtech 6" | PA 3" Body Lift | Bilstein 5100 shocks | 20x10 Rockstars | 37x13.5x20 Toyo MT | Limo Tint on all windows | L-Heads | DDM HID Heads | DDM HID Fogs | DEPO Fogs | Smoked Tails |
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
