Hey guys I'm getting ready to install my tweeters up on the door pillar. They will fit on the flat side facing the other side of the truck or I could put them in the flat spot facing down along my left side and at me right above the defrost ducks. I'm not sure what would sound better. Don't know if having them pointing straight at the driver and passenger above the defrost ducks would be better then them being on the flat sides pointing toward each other on opposite sides. Thanks a bunch for your help!
Scott
Both spots leave the speaker pointing incredibly off axis, so neither spot is ideal for staging and quality sound. Not to mention the path length difference is terrible. You want to mount them as on-axis as possible, maybe slighty off-axis on the driver's side since it is much closer to the listener. If you run passive crossover networks, you do want it to be relatively close to the midrange woofer, but this isn't totally possible in the F150 and will give you a very low stage with no depth at all. If you have active crossover networks, fiber-glassing them into the A-pillar as far forward as possible and nearly on-axis will give you the best stage depth and closer PLDs for less time delay.
If you have to choose between those 2 location, the green circle is better since the far tweeter will be more on-axis to the driver, but don't expect great stage presence.
__________________ 2004 Lariat 4x4:
Troyer, K&N, Borla power - Fabtech, Camburg, Bilstein suspension - Helo bling - Toyo rubber - 12,000 lumens of HID projection -
1900 watts of Scanspeak/Stereo Integrity sound - lots of PTM
Just do this. Cost me 14 bucks at Home Depot and only requires a 3/8 inch hole in the bottom of you a pillar rather than a large 1-2 inch hole in the a pillar or door panel.
