Home Discussion Forums Photo Gallery Product Directory Technical Articles Recalls & TSB's Product Reviews Classifieds Photo Galleries Ford Truck News Event Calendar Advertise with us
F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Audio & Video System > Speakers & Subwoofers
Thread Tools Display Modes
Old 09-18-2008, 10:28 PM
Vehicle: 1997 ford f150
alternator whine in all 4 of my 6x9s
who has any ideas on how to fix it? my amp ground is on the back wall. and my positive speaker connection i used spade terminals and my negative i did not. i bought ground loop isolaters they made my sound more clear but now i cant even adjust my amp and they didnt get rid of the whine. please i need suggestions ive been messing with it for so long and have gotten nowhere.
Old 09-19-2008, 12:57 AM
Vehicle: 2005 Ford F-150
Make sure your power wires are away from your rca's...which means that they are run down different sides of the truck and never come close to each other. Also try to screw a piece of MDF to your back wall, then mount the amp on that... And one more thing to check is your ground wire is the same size or larger than your power wire and that you are using a good ground... paint scraped off to expose bare metal.
Your an Installer, Figure it out.
http://www.f150online.com/forums/mem...to-albums.html
Old 09-19-2008, 01:06 AM
Vehicle: 2001 Ford F150
yep, i'm with proto
Old 09-19-2008, 09:04 AM
MDF? yes my power wire is on the other side of my truck, but the back wall simply just does not seem like a good ground. my - speaker terminals the wire is just tied to it could i not be getting a good ground on my speakers?
Old 09-19-2008, 09:23 AM
Vehicle: 2003 Ford F150
use a solder gun for all connections for one. If you amp has spade connections on it, get some spade's and solder the wire to the spade then plug it in.
second// use a jumper wire to quickly re-run your ground wire to your amps and see if that changes the noise at all. Use this method to try to isolate the source of your problem.
I bought a pioneer head unit and had major noise problems. I had to ground all the (-)'s on the rca's and I had to run a new power wire to the head unit from the battery.
I won't buy another pioneer.
2003 Supercrew, 4x4, 5.4L, 6" Fabtech Lift, 3" PA Body Lift, Superchips Tuner, 38x15.50x20 Toyo M/T's, 20x9.5 Procomp 7005's, Yukon 4:88 gears, 40 Series Flowmaster Dumped, 3" AF1 Intake, magnaflow cats
Wish list(in order): Headers(maybe OBX), true duals w/super 44s, ride-rite airbags w/compressor, , SUPERCHARGER!
Thanks for the SIG krusedisc!
Old 09-19-2008, 01:29 PM
Vehicle: 2007 Ford F150
Get your ground off the back wall, and run a search for proper grounding methods. Because you need to properly ground via DMM.
After that, then start on other things.
SPL is one note... SQ is a flat 20-20.
If ported, always tune to CRF 33Hz... aka the Golden Number
Quote:
Originally Posted by styxnpicks View Post
after he bent me over and called me sally
FS:
JL 500/1, JL 500/1v2, JL 300/4, JL XR 570-CSi
Kicker 1/0, 4, 8, 12, and 16ga by the foot
Old 09-19-2008, 01:34 PM
Just use a jumper like I said to make sure the ground is the problem.
Otherwise you will be go to a lot of trouble re-running wires that don't need to be.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
F150Online.com and InternetBrands, Inc. are not affiliated with the Ford Motor Company
