Jacking up the rear seat - 2000 F150 Supercab
Has anyone ever jacked up the rear bench seats in a 2000 model F150 supercab? I could use some extra clearance for my box and was thinking of jacking the seat up 1-1/2" to 2" with shims or washers. It looks simple enough but I am concerned about the back rest interferring somehow. Can the backrest be moved to?
Any input will be appreciated.
Thanks!
Mike
Thanks!
Mike
http://www.subbox.net
buy a custom box for your truck, and they supply a 2 inch lift, just make sure the subs you own will fit the mounting depth
or
lmi welding
search the sites see whats up, I havent scoped out lmi welding to much so you may want to check if they have it specifically for your year etc
good luck, happy listening
or
lmi welding
Probox makes a perfect fit box that comes with all hardware for raising the rear bench seat for F150's. I have one in my 98 with two Fosgate 10" Punch P2's down firing. They sound awsome.
The box looks extremely good and is virtually un-noticeable. By raising the rear seat it makes the ride for someone sitting in the back more comfortable. Here is their website...
http://www.proboxrocks.com/home.shtml
Check them out, it's worth it...
Dann'O
Dann'O
