Need help wiring my system. (KX120.2 to Audiobahn AW101T sub)
I've wired quite a few stereos, but for some reason my current setup is giving me fits.
I need help, BAD..
I need to know what the best way to wire this amp to sub would be.
I have a Kicker KX120.2 amplifier.
Specs here: http://store.epayright.com/epayright/kx120-2.html
and an Audiobahn AW101T 10" sub:
Specs here: http://www.audiooutfitter.com/store/aw101t.html
I had it wired parallel before and if I turned the receiver up very loud, the amp would shut off..
Then I wired it up bridged, and it will cut out when the car is at idle. As soon as I take off, the stereo will kick back on?
I believe the sub has a dual-voice coil, and I've never wired one up before, so I'm pretty lost about what to do.
THANKS A MILLION GUYS!!
Terry
I need help, BAD..
Terry
It says(the amp) it'll handle a 4ohm load bridged... That's what I'd do. (L+, R-) ...
PS... This sub ISNT a DVC. Maybe that's why it shorts out your amp! ha ha ha.
(EXCURSION CAST FLAME BASKET ****SINGLE**** 4 OHM 450 WATTS RMS)
Another thing, the sub works when RPM's are up? Sounds like another problem... How big is your power wire?
I fixed the DVC short problem.. it doesn't cut out for that reason anymore. I can;t recall the gauge of the wire (I bought the amp wiring kit with the amp from the dealer)
Since I wired it up bridged, it cuts in and out at low rpm's sometime (not all the time)?
It's strange, that's why I am asking for help
Can you explain how to wire it bridged in a little more detail, so I make sure I get this right for once? I'd really appreciate it..
There are 8 wire terminals on the sub altogether.. 4 on each side..
http://www.crutchfieldadvisor.com/IS...impedance=SVC4
Should I wire it like this?
Thsi is what Crutchfield is telling me to do..
I searched the internet for you> have you seen this before?
http://www.audiobahninc.com/tech/wir...ug_wiring.html
then
look at: 1. sub wiring.
It has pictures of how to wire the connections. That is what I would do.
So what's up with this model... It does look like a DVC, the manual states its not, the wiring diagrams have their own separate section for DVC's, anyway, the deeper I dig the more confusing it gets. I think it's time to bury my MECP!
Maybe someone else can help clarify things.
then
Maybe someone else can help clarify things. [/B]
Maybe I'll call Audiobahn..
*sigh*
*sigh* just trying to find out how to hook up a 10" sub & amplifier. I have a 1993 F150 Flareside Extra cab (not super cab) and I've upgraded to a nice panasonic stereo, 2 way pioneer 6x8's in back and sony 6 1/2's in front. None of these have significant bass so I want to add a 10" woofer with rampage amplifier (i know, cheap amplifier, but not looking for anything hella loud) I already have a 10" pioneer subwoofer. I cant find any info on how to hook this up.
