how to remove the speakers on a 2004 screw
Yeah, the front grilles have a little slot near the top that you can put the tip of a screwdriver in and they just pop off.
The back doors are different. You have to pull off the upper molding (that goes up the back side of the window), and that will reveal a bolt. Remove that bolt. Then pry off the tab where the door handle is and remove those two screws. Gently pry up on the door lock panel and you'll see another screw there to remove. Then there are two screws at the bottom of the door panel. After all of the screws are removed, you can lift up on the door panel and it comes right off. Speakers are right there for the taking.
That's from memory, so if I left a part out, someone plz correct me.
Originally posted by CrazyAssNick
how about the back doors on a scab?
