Help w/Cut-Through on Lightning?
Ok, I've decided to do the Cut-Through on the Lightning. I already have a fiberglass toneau and Bedrug carpet bedliner. For the sake of saving some time I purchased a vented Subzone HP112 enclosure that was designed for my 12" Orion H2 sub(It's 1" MDF so it should hold up fairly well).
My thoughts are that I will only make the cut-through large enough for either the port or the sub itself. Which would be best, if you look at the enclosure the sub is mounted on the opposite side of the port. I am going to leave the stock carpeting on the back wall of the cab, so that from inside the truck you will not be able to tell that there is a cut-through. Also should I seal between the enclosure and the bed of the truck? Thanks Guys!
Brent
Brent
