97 F-150 Extended Cab System Install
Old 12-31-2004, 04:51 PM
nd4spdguy2827's Avatar
I have a 97 Extended Cab. (4) 6x8's in all the doors. I currently have a Fosgate 900w. mono channel amp. I want to do a complete system install four new 6x8's and 2 8's in the back. New Sony Deck. Can anyone tell me how to get the door pannels off on all the sides? What OHM subs do I need? What circut do I use?(Parrell?) Thanks for all the Help!
Old 01-03-2005, 10:11 AM
frostby's Avatar
Here's the link to getting door panels off:
http://www.modernengineuity.com/tech...r_install.html
Sure you can wire those baby's in parallel. Rockford amps can handle a 2 ohm load, but do your subs have the ability to handle that much power? -Or are you still shopping. I'm not gonna recommend an impedance w/o some more #'s -like sub handling power.
Old 01-03-2005, 06:03 PM
Bartak1's Avatar
And what model is the amp? Is that 900 watts peak or RMS, and at 2 or 4 ohms?
Old 01-12-2005, 11:43 PM
I had the amp hooked up to two 12" 8 OHM subs. I dont know much more all help is helpful..
Quick Reply: 97 F-150 Extended Cab System Install
