??Shallow Mount Sub?? HELP !!
I made a big mistake a bought a cheap box from ebay to fit in my 01 Screw. My problem is simple. I CANT FIND A SPEAKER TO FIT. These are the specs of what I need. Basically 4 5/8 mounting depth or less that works in .7 cubic ft. air space. I need ideas something that can handle 200w RMS that will sound good. Hopefully its out there. Thanks for you help.
with that amount of depth available, your only going to be able to go with an entry level sub. You might think about the punch P1's or maybe an audiobahn. Depending on how much room you have under your seat you might be able to fit a spacer on the top of you box, its basically a piece of mdf cut to fit the top of you box with the speaker hole cut out.....it basically just gives you another 5/8" of clearance.
good luck
good luck
