shift kit
Old Jul 28, 2000 | 08:28 AM
ib fast's Avatar
Cool shift kit
can someone tell me if it's a good thing to scratch between shifts?had transgo installed and bolt scratches a little between 1st and second but it does that with just a chip. so after i put cats back on [lost low end tourqe]if it still doesn't scratch should i drill bigger holes that come with kit? is scratching a plus or a negative for e/ts?did a search on this and no one talks about if scratching between gears will help or hurt[loss of traction] your e/ts. thanks
00 black team swanson
[This message has been edited by ib fast (edited 07-28-2000).]
Old Jul 28, 2000 | 08:34 AM
Yoda's Avatar
losing traction between shifts is bad, it does mean you have more power, but it is being waisted on chirpng the tires. You just nedd sticker tires
99' SVT Black Bolt NLOC #392
best run 13.54 @ 101.35
**The Storm over Phoenix**
Old Jul 28, 2000 | 05:10 PM
BRIMSTONE's Avatar
Had Transgo install my shift kit for me - spinning the tires between shifts is unnecessary and will of course cost you time.
Mike
Old Jul 28, 2000 | 09:48 PM
FORDSALES's Avatar
and MONEY
Old Jul 28, 2000 | 10:01 PM
Silver_2000's Avatar
But its FUN !!
And it means that you have more torque than the tires and pavement can handle.
Would I rather drive a Ford Ranger that I can smack the hell out of and never get good power and speeds? Or drive a Lightning and have to pedal it to keep traction, or otherwise change the coefficient of friction, Upgrade tires, add weight, change air pressure, etc etc
I’ll take the Lightning and save my pennies for tires…..
Only reason I havent done the shift kit is I am not sure the Auto will handle the torque long term. I would like to try to keep the warranty on my side. Plus PSP chip shifts good, dont think I need more....
Doug
[This message has been edited by Silver_2000_! (edited 07-28-2000).]
Old Jul 28, 2000 | 10:15 PM
BRIMSTONE's Avatar
I believe someone on this board who works on Ford trannys said that ours can handle up to 1000 ft.lbs. of torque so HOPEFULLY a shift kit + chip won't be too much to handle.
Mike
Old Jul 28, 2000 | 10:34 PM
Burninout101's Avatar
Im I reading this right "I believe someone on this board who works on Ford trannys said that ours can handle up to 1000 ft.lbs. of torque"
Old Jul 28, 2000 | 10:38 PM
SilverBullet's Avatar
I believe you are refering to this: https://www.f150online.com/f150board...ML/003872.html
A bit misleading...
