Front Brake Pads Pt#
Old Jun 17, 2000 | 10:02 AM
MRBBQMAN's Avatar
Question Front Brake Pads Pt#
i did a search, and Nathan said to order pads for a 99 F-250 non SD w/4wh discs, counter "guy" says reg F-150 pads. if anyone has the ford pt# out of the manual, i would appreciated it, so i can bypass the human (and his errors) and order the correct pads
Old Jun 17, 2000 | 10:19 AM
SilverBullet's Avatar
I don't have the stock ones, but I have the performance friction part numbers:
Standard CM's:
Use the pt 0702.20 front and 0711.20 rear.
Z-rated:
0702.10 for the fronts, no rears.
Old Jun 18, 2000 | 03:56 PM
Hawkeye's Avatar
According to the Helm's manual the front pads are part number 2001 for all applications; F150, F250(LD), 2WD or 4WD. They don't give any part numbers for the rear pads, but they do refer to them as "Lightning and F250 option".
I think the parts guy and Nathan are correct for front pads, and Nathan is also correct about rear pads.
[This message has been edited by Hawkeye (edited 06-18-2000).]
Old Jun 19, 2000 | 12:18 AM
MRBBQMAN's Avatar
thanks Silver, i've used these in the past and had a lot of brake squeal. anyone had luck with these on the lightning? anything better?
Old Jun 19, 2000 | 01:54 PM
BABolt's Avatar
Talking
Use genuine Ford parts. Part number for the front pads F75Z-2001-AA and for the rears XL3Z-2200-AA ( the Z in the part number tell you that it is a service part)
BABolt
SVT#290
Old Jun 19, 2000 | 02:15 PM
MRBBQMAN's Avatar
Thumbs up
Thanks BA, i've always had better wear out of the OEM's
