Fuel pressure drops to 0 after 10 min. on shut down
Old 03-26-2017, 03:00 PM
oldsgt's Avatar
My fuel pressure drops to 0 after shut down. On restart injectors tap loud for 30 sec. Is there a pressure valve that holds the fuel pressure after shutdown ?
Old 03-26-2017, 03:07 PM
projectSHO89's Avatar
Yeah, there's a check valve built into the fuel pump assembly.
Old 03-26-2017, 03:46 PM
oldsgt's Avatar
Thank you! I thought that might be it.
Old 03-26-2017, 04:25 PM
You sure that it's the injectors that are tapping? I'd suspect the lifters, what brand oil filter are you using?
Old 03-26-2017, 05:33 PM
oldsgt's Avatar
I have a stethoscope and it is the fuel injectors not the lash adjuster. after the pressure drops they tick for about 30 sec. I thought it might be the lash adjusters at first too. I use Mobil 1 .
Old 03-29-2017, 01:48 AM
oldsgt's Avatar
It was the fuel pump
Old 03-29-2017, 09:17 AM
Couldn't you have turned on the ignition for a few seconds before starting to allow the pressure to build before starting?
Old 03-29-2017, 01:33 PM
oldsgt's Avatar
I tried that at first but it was a pain for my wife. I thought it was better just to change it (with 100,000 miles)
Thanks to all.
Old 03-29-2017, 01:50 PM
With 100k and 9 years, I'd check the FPDM for corrosion.
