trans fault on, od light flashing, need help please
2007 f150 xlt 2wd w/ 4r75e.
OD light flashing, Trans fault light message, whining and slight raddle noise inside trans, rpms go up and down when driving, doesn't seem to go above 3rd gear, feels like parking brake on when in reverse. any help would be appreciated.
I should also add I had a complete rebuild done on my trans about 2yrs ago (40,000 miles) from amco transmissions which is now out of warranty.
Thanks Darrin I've read some of your post in the trans forums for others and you seem very knowledgeable. I have found a 4r75w trans used that came out of 2004 crown vic interceptor that is reasonably priced. I was wondering if that would work in my truck straight swap? that's the best option I have found so far seeing as I don't have another $2600 to spend on a complete rebuild again. Thanks again
