01 F250 starts but shuts right off
Old 02-20-2017, 09:45 PM
Fence Guy's Avatar
My 01 F250 stalled when I stopped at a light today. It started right up but shuts right down unless I give it gas. It will drive if I go from neutral to drive and hit it. I have to drive two footed to keep from stalling when I slow down. Not sure what the hell it is. Any ideas?
Thank you,
Bill
Old 02-20-2017, 10:00 PM
projectSHO89's Avatar
Probably either a failed IAC valve or a vacuum leak.
Old 02-20-2017, 10:05 PM
Fence Guy's Avatar
Would I get a code?
Old 02-20-2017, 10:49 PM
Not necessarily. If it's a vacuum leak big enough to cause it to stall, you should get lean codes. If it's a stuck or failed IAC, probably not.
Old 02-20-2017, 10:59 PM
Fence Guy's Avatar
I was able to nurse it home but as I got closer, it got worse. It was sputtering and died 3/4 of the way into my driveway. I started thinking the fuel gauge was messed up and I was running out of gas. It would not restart. I got gas tonight and put a few gallons in hoping that was it. It started but wouldn't keep running and it took a lot to get it further up driveway. It was very choppy is the only way to describe it.
Old 02-21-2017, 10:40 AM
When was the last time you changed the fuel filter? You can do a fuel pressure test at the Schrader valve on the fuel rail. It should be 28 to 40 psi, you can get a loaner gauge at most parts stores.
Old 02-21-2017, 10:24 PM
Fence Guy's Avatar
Thanks for the input guys. Found the problem 30 seconds after opening the hood this afternoon, never hooked up the hand held or took out a tool. A hose off the air filter box fell off the clip that holds it and popped off the back of the motor. I saw it right away,lol. Popped it back on and in the holder and it fired right up.
I appreciate all the input!!
