King Ranch
Did I screw up?
Old 01-12-2017, 03:06 PM
Drobson's Avatar
Did I screw up?
I've been having problems with my speedometer not reading accurately. For some reason, it will read less MPH than actual speed. (Speed measured with GPS). For instance, gps says 75, and speedo reads 55.
I've just ordered a replacement speedo cluster, (used), off e-bay. I will probably have my dealer replace it, but am wondering about re-programming the replacement to reflect the mileage on the current speedo. What's the consensus of the members about this?
2006 King Ranch
Old 01-12-2017, 03:12 PM
Do you have taller tires that the original factory tires? Have gears been swapped?
Old 01-12-2017, 03:42 PM
Drobson's Avatar
Not a problem with tires and no gears have been swapped. This is an intermittent problem that occurs occasionally. Things are normal for many, many miles, and all of a sudden while driving, the speedo acts up.
I have replaced the alternator, and installed a new battery, as these were suggestions from the members here on an earlier post I made.
Old 01-23-2017, 03:39 PM
BROTHERDAVE's Avatar
how much did you save buying ebay as compared to buying new?
when i was younger i got so into "saving money" I sometime bought things I didnt need because of the price difference.
Old 01-23-2017, 04:58 PM
Drobson's Avatar
My dealer said a new cluster is about $750.00, just for the cluster. Bought a used one, same year, etc., as mine, for $75.00. Only problem, I don't know how many miles are registered on the one I bought.
The reason for my question about screwing up, is, as I understand it, the change will have to be recorded as being made, which will show up at dealers and Car Fax, etc.
Maybe I can put the replacement one in and then have the original repaired leaving the original miles on it. Then swap them back. I don't know.
Old 01-24-2017, 07:41 AM
I believe you'll have to program for PATS before you can use the swapped cluster
Old 01-27-2017, 10:08 PM
yep gonna have to have it programmed anyway
and the mileage is stored in the ecm
