4WD won't disengage at road speed
I can't find an answer to this in the forums. If I engage the system on the fly so to speak, it won't disengage until I stop. It goes into 4wd immediately when the switch is switched to 4hi. The dash light illuminates within 2 seconds. However, when I switch the switch back off the dash light goes off within 2 seconds, but you can clearly hear it's not released and it hunches going around corners.
When stopped with the front wheels off the ground you can clearly hear the xfer case motor engaging and disengaging and both hubs operate instantaneously. While moving around my property at 2 or 3 miles an hour the system also kicks in and out normally, just not between 15 and 45 miles and hour.
Both hubs are within 2 years old and the vacuum solenoid has been changed. Anyone got an idea what to check?
Actually it does, no? He has no problems at low/no speed with it disengaging. Unless he rigs up a camera, he can't be sure if it's doing the same at speed. The transfer case may very well be disengaged in both scenarios, just that the 4WD components are still being parasitically driven by the wheels.
