Tire Pressure Fault
Have you checked your Owner's Manual? I know there's a "Reset" procedure in mine. There probably is in yours also.
How do you know your sensors are sending good signals? From the age of your truck, I'd suspect the sensor batteries might be just about used up. You may need to replace them.
- Jack
- Jack
I have a 2010 with aftermarket rims and 35s, but over the past year when I go on long trips mine has gone off a few times while driving, but tire pressure was fine. Usually it auto resets after it sits and I start it back up. It went off last month while sitting in a parking lot, but it was an actual low reading in one of my tires, so looks like it still is working, but after almost 8 years I bet they are in need of replacing. I'll do that when I get new tires this year.
