Bed Extender
Old 12-01-2016, 09:43 AM
robl4's Avatar
Bed Extender
Will a bed extender from my 2013 F150 fit a 2016 F150?
Ford Accessories show different part numbers. Has anyone tried to install one?
Old 12-01-2016, 10:09 AM
JackandJanet's Avatar
Hi rob, and welcome! There was a significant redesign in the body of the truck between model years 2014 and 2015, so I doubt it. The bed extender I had for my 2005 truck would not fit my 2014 without some significant modifications, so I bought a new one for it.
You SHOULD be able to look at the beds of a 2013 and 2016 truck to see the differences. You might have to make measurements of things like the mounting holes and their positions. From that, you should be able to make an informed decision.
- Jack
Old 12-01-2016, 01:04 PM
Fifty150's Avatar
What happens when you check with the manufacturer? Don't they produce an extender specified for your year, make, and model? I am afraid that you will have to buy new accessories. Not everything fits from year to year.
Old 12-01-2016, 05:56 PM
Timc74's Avatar
Yes it will.
Old 12-01-2016, 11:14 PM
Originally Posted by Timc74
Yes it will.
Hello Timc - you may be right, but rob, I'd be a little leery of this advice from a 1st time poster.
- Jack
Old 12-02-2016, 03:47 AM
robl4's Avatar
It does fit fine. Everything lines up with the exception of the lock pin and the hole on the tail gate. It also is a little harder to turn on the box lights when extender is folded and tonneau cover closed but for $200 it will work fine
Old 12-05-2016, 05:46 AM
Timc74's Avatar
- Jack
I had it in my 2013 and installed it in my 2016
Old 12-05-2016, 08:47 AM
Wookie's Avatar
- Jack
Ummm, not true. I kept the extender from my 2005 and put it on my 2011. The only changes required were to drill two holes on each side of the plastic bed liner. The holes were even already marked on it. The mounting hardware was different but the threaded holes were the same. Something might have changed between the 2011 and 2013 beds but I suspect not.
For the aluminum body trucks I'm not sure but do suspect some parts might carry over but the different in bed options might throw it off.
Old 12-05-2016, 10:03 AM
Wookie, I can only speak from my experience between my 2005 and 2014 trucks. The spacing where the extender mounted in the bed is wider (as I recall) in the 2014 than it was in the 2005. And the threaded holes were a different diameter in the new truck. The extender I used in the 2005 was a one-piece aluminum tube device (aftermarket?) and it just would not fit properly.
I'm happy with the two piece, stow-away extender that I bought and it lives permanently in my truck.
- Jack
Old 12-22-2017, 10:31 PM
Fordguy15's Avatar
I recently bought the OEM bed extender for a 2013 F-150 off Craigslist and it fits fine in my 2015. The lock pins line up on each side. The only thing that doesn't line up is the lock pin on the tailgate when the extender is flipped out resting on tailgate but I'm ok with that since the lock tabs work on the side and I'll use it mostly flipped inward so stuff stays towards the tailgate with gate closed. Here's some pics
Attached Thumbnails Bed Extender-photo495.jpg   Bed Extender-photo355.jpg   Bed Extender-photo43.jpg   Bed Extender-photo348.jpg
