It's here!
It's here!
It's all going on my 2008 5.4L. The quality is second to none on these longtubes. The tips are Stainless Works 2.5" inlet, 4" outlet double wall. I love the profile. The muffler was supposed to be a 2.5" inlet, dual 2.5" outlet. The part number corresponds to that, but they stuffed the 3" inlet, dual 2.5" outlet in the box. The Y-pipe that comes with the longtubes is 2.5" in/out, so I may have to order up a Maggie 2.5" in/ 3" out. Those are 4.5" center to center, the same as the Stainless Works kit.
This should be interesting
So the headers are getting installed tuesday. I'm having it done at a local Ford dealer. Their rates were comparable with shops near me, and with no less than 5 studs already broken, and surely more to pop, who knows better working on a 5.4 than the Ford techs? Problem is they don't do custom exhaust work. They will install the headers, high flow cats, down pipes and the Maggie 2.5" to 3" y pipe using the supplied clamps and then they will tack weld everything.
But that's all they'll put on
So when I pick it up I'll have longtubes and a y pipe, and then I'll have to drive about 1/2 hour to my preferred exhaust shop. I think it might be a bit loud and if any police are near me I might feel like getting there.
Should be a fun ride, huh?
Got it back, headers, cats and you pipe installed. Loud isn't the word. This think sounds angry! I'll be putting the pro xs on in a few days, but I don't know if that'll quiet it down enough. Only real issue is the o2 extensions that came with the kit don't have the slots aligned like on the factory harnesses, so I gotta get those swapped out. I'll try to get videos asap.
