2015 factory door code location?
I just bought a 2015 F150 Supercrew. It came with only one key and no door code. I've spent half the day searching the internet and the truck for the factory reset code. Hundreds online say on the 2014's and older, it is on the passenger side kick panel but if it's there on the 2015, I can't find it. Will someone confirm thats where it is or suggest another place to look?
Thanks in advance
Joe
Thanks in advance
Joe
Found it!!!
They make you hunt for it but it is there! I can't say it's the same for all but, on my 2015 F150 Supercrew, it is on the back of the fuse panel in the passenger side kick panel. It is almost impossible to see but if you take both pieces of plastic off, you can just see the sticker on the back. I used an inspection camera to see it clearly. It may be easier to remove the fuse panel and turn it over if you don't have an inspection camera. It even says "key code" next to the code.
Thanks for all that responded and I hope this helps others.
Joe
Joe
glc,
It's on the fuse panel as in the video but on the back side next to the metal, not on the front as in the video. I found several video's online showing it to be in the kick panel but none showing it being on the back of the fuse panel. Prior to posting on this forum, I removed the glove box and several other pieces from the passenger floor area and was convinced it was not there. It's everything but impossible to see without unbolting the fuse panel. I could see a sticker on the back of the fuse panel after I removed the curved plastic piece but couldn't clearly see what was on it without an inspection camera. You may be able to see it if, after removing the curved piece by the door, you insert a small mirror into the 1/2" gap between the fuse panel and the truck.
