Power Window won't roll down when below 50 F
Old 10-06-2016, 10:18 AM
BustedKnuckle's Avatar
Driver’s side door power window does not roll down when it is below 50○F. When the switch is pressed all that happens is a click from the actuator or switch, but it does not engage.
I have lubricated the window track, but this did not help. There is no exposure to water, and temperatures are well above freezing. As soon as the door warms to above 50○F, the window motor works fine and runs strong.
It is like there is something electronic that happens right at that temperature mark. (Works great all Summer)
Normally I can tap the interior of the door hard with a rubber hammer and eventually the actuator will resume working, so it is like it is locking up or has a bad connection. If that were the case, it would do it in warm weather too.
I’ve seen countless threads on this same topic on various makes and models of cars and no one has a good answer. I’ve tried all the suggestions, looking for someone that KNOWS what the cause is, and not guessing. I don't want to buy a new actuator if it works fine for 6 months out of the year.
2003 XLT SuperCrew, 4.6 V8, 2WD, dual exhaust, brown floormats (=
Old 10-22-2016, 02:04 PM
The great mystery continues? No one knows?
Quick Reply: Power Window won't roll down when below 50 F
