7700 package axle shafts
Dorman makes them and they are available from rockauto. There is a tag on the rear that will help identify the axle. The larger one on the left is yours I think. I ordered the wrong one and had to send it back and get the smaller one like the one on the right. Except that yours will have 7 lugs.
Correction! Dorman doesn't have 7 lug axles. I just looked!
exactly...I had searched the major websites under F150 and no 7 lug axles
but they're out there...
http://www.justdifferentials.com/AXF.../axf100005.htm
thanks for the help everyone!
turns out - the axle shafts/differential drive just fine. The "clunk" I feel only happens on CNG...I'm guessing the CNG system isn't working properly, so it is signaling the transmission all wrong. The shifts get sloppy and the torque converter lock up isn't operating properly.
When I drive on gasoline, it drives without those symptoms. It still has a little more "slop" in the differential than my dedicated CNG F-150, but not worth spending $1,100-$1,500 to have fixed.
I'm not going to swap the axle anymore...but I will likely get my CNG system serviced
