help!!!!!!!!!!!!!!!!
I have a 97 f150 4.2l v6 with 4x4. I just finished replaceing tie rods. counted threds as i removed and replaced one at a time. when i finished i went for an alignment and noticed my tires were flopping over on turn and have a severe tilt to them. am going to try to adjust them myself but just in case are they backwards i put them onthe way they came off but i see pics with the loose boot being the inner on some. is that my problem?
tie rod ends only affect the toe-in. The upper and lower control arms control caster and camber. I don't think you can adjust either without replacing the upper control arms with the adjustable type. Take it to an alignment shop and get it aligned. It's probably okay. I'm assuming your truck's front end is the same as my 02.
