Field find, no brakes
Okay, just got a 1991 F250 from my Uncle. It was parked in his field for the last 5-10 years.
Got the engine running, but now I find there are no brakes whatsoever.
Pedal goes straight to the floor with no resistance. The linkage is okay. I can hear some booster hissing as well.
No leaks noticed and the reservoir seemed a little low but that could be just worn pads.
What would cause the pedal to do this? First I thought booster, but if that was the case wouldn't I still have some pedal resistance?
I don't think that ABS can cause the pedal to drop all the way to the floor. I think the brake system is designed so that you can ALWAYS operate the brakes manually even if the brake booster and/or ABS fails. My guess is that your fluid has leaked out or (mostly likely IMO) bad master cylinder. That's not saying that the booster and ABS are ok but I don't think that they're the cause of the problem that you described.
I'm on the failed master cylinder bandwagon. If it isn't leaking anywhere and the pedal goes straight to the floor odds favor that the seals have gone bad in the master cylinder.
As mentioned, after sitting that long unused you should make sure all the brakes are moving freely and the lines and hoses are good before you get it out on the highway. A stuck caliper or bad wheel cylinder isn't something you want to find out about at 55-70 mph
