Gearing info mpg / rpm 4.10& 4.56
I have read a lot of posts relating to gearing but not exactly the info I am looking for so this is what I am searching for if anyone can help
original :2005 F150 4x4 5.4l Lariat automatic 3.73 gears with 285x65-18 tires (roughly 32.5") I do occasional towing of a 10K trailer any helpful info would be great
.70:1 4th gear ratio
**looking for info for 4.10 & 4.56 gears ** @ with about 34" tires
ball park MPG city/highway & engine RPM @ 70 mph
Thank you
Thank you
According to our calculator, with zero overdrive, the 4.10 yields 2967 rpms, the 4.56 yields 3300. Not knowing what transmission you have or the overdrive ratio, I can't put that info in the calculator. Once you determine the overdrive ratio, multiply it times the rpms and viola, yer answer for it in OD. Gas mileage, take a wild guess. It'll be just as accurate as anybodys guess.
also if you could the 32.5" and 34" tires
thanks
