6r80 slips and high line pressure
Old 06-29-2016, 10:52 PM
fennanthony's Avatar
I'm having an issue with the 6r80 in my 2012 F150. 4-6 gears slip and also have really high line pressure, like over 300psi sometimes. 1-3 gears act behave normally and have expected line pressure. Fluid is also really high, high enough that every time i pull the dip stick it leaks more out of the fill hole.
Open to ideas.
Thanks,
Anthony
Old 07-05-2016, 07:10 AM
ane182rf's Avatar
Open to ideas.
Thanks,
Anthony
Did you try the simple things first like replacing the tranny filter, verifying correct fluid capacity within trans, checking for blocked lines/cooler. What's the history and mileage? Did this just happen overnight after 50k miles of smooth operation?
Quick Reply: 6r80 slips and high line pressure
